RGB pins on MEGA2560
Hello,
I know that BITS 2 to 13 ( located on J1 and J2 connectors) can be used for MOOD lighting. I used them and it works fine.
My question is if I can use any other pins for the MOOD lighting.
Can I use any of the bits 22 to 51?
Thanks
I'm going to hazard a guess that you want to use PWM output pins and analogWrite() to dim LEDs. If you look at the documentation for analogWrite() you will see a list of PWM output pins for various Arduino models:
On most Arduino boards (those with the ATmega168 or ATmega328P), this function works on pins 3, 5, 6, 9, 10, and 11. On the Arduino Mega, it works on pins 2 - 13 and 44 - 46.
Hello,
I looked at the link you sent. It says
"On the Arduino Mega, it works on pins 2 - 13 and 44 - 46."
So I can use pin 44, 45, and 46 for LED Mood lighting.
That is what I needed.
Thank You very much.
Bobby
