RGB strip, controlling the void loop?
hi guys, i'm not a programmer i'm new to coding.
i'm installing some 2812b rgb strip to my stairway.
my code seems to work fine, except for one thing.
when i activate the pir at the bottom of the stairs...
it activates the leds. (happy days)
but then it loops and loops and loops.
how do i stop that loop until the next interupt occurs?
#include Adafruit_NeoPixel.h
Adafruit_NeoPixel strip = Adafruit_NeoPixel(81, 6, NEO_GRB + NEO_KHZ800);
int motionPin = 10; PIR Input pin 8, UPSTAIRS
int motionPin2 = 11; PIR 2 Input pin 7, DOWNSTAIRS
int senseMotion = 0; variable to hold current state of motion detector
int senseMotion2 = 0; 2nd variable for 2nd sensor
pinMode(motionPin, INPUT); PIRs declared as inputs
pinMode(motionPin2, INPUT);
strip.begin();
strip.show(); Initialize all pixels to 'off'
senseMotion = digitalRead (motionPin); set variables equal to what our sensors are reading (on or off)
senseMotion2 = digitalRead (motionPin2);
if (senseMotion == HIGH senseMotion2 == HIGH) { Testing both sensors at same time, if high, go to apropriate line.
if (senseMotion2 == HIGH) { If Upstairs motion sensor is triggered...
colorWipe (strip.Color (0, 0, 150), 50); Whiteblue color sweep going up stairs (Towards the arrow on the strip)
strip.show(); This being enabled or not, doesnt seem to make a difference. NVM it looks like its more responsive when trying to activate the PIRs one after another
delay (6000); Wait so someone can get to the bottom or top of stairs, will remove this when 2nd sensor is implemented with an interrupt
colorWipe (strip.Color (0, 0, 0), 50); This is needed for turn everything off, clear all pixels. More efficient with this here
strip.show();
if (senseMotion == HIGH) { If motion sensor 2 (Downstairs) if high go to next line
colorWipe2 (strip.Color(0, 0, 150), 50);
strip.show();
delay(6000);
strip.show();
else { no motion = no lights or animate til off
digitalWrite (motionPin, LOW); turning motion pins low, doesnt seem to make a difference either.
digitalWrite (motionPin2, LOW);
colorWipe (strip.Color(0, 0, 0), 50);
strip.show();
Function time!
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; istrip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
strip.setPixelColor (0,0,0),50);
delay(wait);
@razzle1
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
if (senseMotion == HIGH senseMotion2 == HIGH) { Does this even compile?
Do everyone a favour and follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
You don't appear to have an interrupt in your code.
