I'm trying to figure out how to have the RGB switch colours each time the Piezo sensor is activated..
so it goes like this:
Hit once, RGB shows yellow for 5 seconds then turns off.
Hit twice, RGB shows orange for 5 seconds then turns off.
Hit thrice, RGB shows red until the arduino is switched off.
Currently I'm able to make it show all 3 colours when hit (based off the knock codes) but I'm not able to separate them into different instances..
You make it sound like the piezo sensor is a digital sensor - on or off. It is NOT.
My crystal ball says to fix lines 27 to 35 of uselessCrap.cpp. But, I think it might be broken. You should probably read the sticky posts at the top of this forum for a clue.
