I use my RGB led strip like this with IoT cloud sliders, but now I want to control it with Alexa and it requires me to change this to "color light" variable. And cause I really dont know how to use this HSB variable Im stuck... Can someone help me with this?
I have IoT cloud project and I use RGB LED with sliders as I said above. But now I`d like to use Alexa which requires that I need to change my redVal, greenVal and blueVal int variables to this CloudColoredLight variable which does include switch and HSB LED control.
And cause my RGB was pretty simple I have no idea how to use CloudColoredLight...
I guess there is no need to convert RGB to HSB (I could be wrong though). I just need to switch RGB code to HSB code, but I couldn`t find any examples of that...
It seems that actually reading isn`t your strength... Like I said I´m not necessarily converting anything. What I need is help to use IoT cloud colored light function as it is meant to, cause it does not work with my code.
This was it... Took me shamefully long to actually understand what I was doing. But anyway problem solved with this. Of course it needed a little tuning but works perfectly. I tried this at first with nano rp2040 bult in RGB led and colors were all over the place... But then I just bravely applied it to my project and it works as it should.
