RGB_music
RGB_music.ino:8:19: error: expected unqualified-id before ‘{’ token
RGB_music.ino:15:18: error: expected unqualified-id before ‘{’ token
Ошибка компиляции.
my code
int LedR=9;
int LedG=10;
int LedB=11;
int sensorPin=1;
int Ssensorval=0;
void setup ();{
pin Mode (LedR, OUTPUT);
pin Mode (LedG, OUTPUT);
pin Mode (LedB, OUTPUT);
Serial.begin (9600);
void loop ();{
sensorval=analogRead(sensorPin);
Serial.println(sensorval);
digitalWrite(LedR,LOW);
digitalWrite(LedG,LOW);
digitalWrite(LedB,LOW);
delay(1);
if (sensorval>10) { digitalWrite (LedG,HIGH);}
if (sensorval<25) { digitalWrite (LedG,LOW);}
if (sensorval>25) { digitalWrite (LedB,HIGH);}
if (sensorval<40) { digitalWrite (LedB,LOW);}
if (sensorval>40) { digitalWrite (LedR,HIGH);}
delay(1);
Where is inaccurate ?
This is how you should post code. I have corrected for you also.
int LedR=9;
int LedG=10;
int LedB=11;
int sensorPin=1;
int Ssensorval=0;
   void setup () {
   void loop () {
     delay(1);
     delay(1);
This should compile and upload. But there are other “inaccuracies” I suspect. Test it.
Thank you so much
