Ciao
Rieccomi con lo step successivo per il progetto di datalogger radio
Sotto lo sketch del trasmettitore
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp-now-esp32-arduino-ide/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0xA0, 0xA3, 0xB3, 0x2F, 0x84, 0xC0};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
char a[32];
int b;
float c;
bool d;
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
// Init Serial Monitor
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK){
Serial.println("Failed to add peer");
return;
// Set values to send
strcpy(myData.a, "THIS IS A CHAR");
myData.b = random(1,20);
myData.c = 1.2;
myData.d = false;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
if (result == ESP_OK) {
Serial.println("Sent with success");
else {
Serial.println("Error sending the data");
delay(2000);
Sotto lo sketch del ricevitore
Rui Santos
#include <WiFi.h>
// Structure example to receive data
// Must match the sender structure
char a[32];
int b;
float c;
bool d;
} struct_message;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Bytes received: ");
Serial.println(len);
Serial.print("Char: ");
Serial.println(myData.a);
Serial.print("Int: ");
Serial.println(myData.b);
Serial.print("Float: ");
Serial.println(myData.c);
Serial.print("Bool: ");
Serial.println(myData.d);
// Initialize Serial Monitor
// Init ESP-NOW
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
e qua sotto la stampa sul serial all avvio del modulo ricevitore
17:11:16.279 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
17:11:16.279 -> configsip: 0, SPIWP:0xee
17:11:16.279 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
17:11:16.279 -> mode:DIO, clock div:1
17:11:16.279 -> load:0x3fff0030,len:1344
17:11:16.279 -> load:0x40078000,len:13964
17:11:16.279 -> load:0x40080400,len:3600
17:11:16.279 -> entry 0x400805f0
17:11:16.605 -> A0:A3:B3:2F:84:C0
17:11:18.604 -> A0:A3:B3:2F:84:C0
17:11:20.622 -> A0:A3:B3:2F:84:C0
Le mie domande sono diverse
Il loop e' vuoto, perche' su rx ricevo continuamente il mac del rx?
All avvio non dovrei ricevere anche
myData.c = 1.2;
myData.d = false;
Ultima domanda, come faccio a mettere nel loop del ricevitore la funzione di ricezione
