Ridiculously nooby question
Hey, I’m new to Arduino, and I am having some trouble with a project from the
projects book (included in the basic kit).
The project in question is no. 07: Keyboard Instrument.
I have written the code exactly (I think) as written in the book, and it returns this error:
soundsketch.ino: In function ‘void loop()’:
soundsketch:10: error: ‘keyVal’ was not declared in this scope
soundsketch:11: error: ‘AO’ was not declared in this scope
As I am new to this, it might be an incredibly easy question to solve, so don’t laugh too hard :stuck_out_tongue:
Here’s the “correct” code for reference:
int notes = {262,294,330,349};
int buttons[6];
void loop(){
Serial.println(keyVal);
int keyVal = analogRead(AO);
if (keyVal == 1023){
tone(8, notes[0]);
}else if(keyVal >= 990 && keyVal <= 1010) {
tone(8, notes[1]);
else if(keyVal >= 505 && keyVal <= 515){
tone(8, notes[2]);
else if(keyVal >= 5 && keyVal <= 10){
tone(8, notes[3]);
Hi, before setup you need line
int keyVal;
also change AO to A0,, ie A zero.
also select tools and select auto format.
It will improve the look of your sketch and make it easier to read.
And see what that produces.
Tom... :slight_smile:
try this link to see how to post your sketch code.
Try Azero, not Aoh.
Also, when you post code snippets, highlight the code block and click the "#" button (above the smileys) to wrap it in [ special tags ]. This will ensure your code displays properly.
Thanks a lot!
Now the code doesn't return any errors at all!
There's probably some trouble with the hardware/I've done something wrong, as nothing happens when I press the buttons,
but thanks for the help!
The problem with keyVal in the first listing you posted is that you used it in a Serial.print in the line just before you declared it. If you swap the first two statements inside loop() (and change AO to A0) so it is like this"
void loop(){
int keyVal = analogRead(A0);
if (keyVal == 1023){....
it should work ok for you.
