Right Direction
Hello,
I need some direction for success in a new project. Here are my requirements:
Lock Box Project
Send and Receive cellular data including [u]SMS[/u] Read and Write cellular data to Micro SD Card Read NFC data from iPhone and Android phones Actuate solenoid lock RFID to detect object removal and return (like 'Key Fob')
I'm just looking for a proper shopping list so I don't purchase in error. :confused:
Thank You!
Brad
Sounds like a "concept" project. which specific components have you looked at so far? What have you done on your project so far to verify you can implement your project successfully with the hardware you mention?
Send and Receive cellular data including SMS
  • You can write to an SD card whatever data you have available at/with your Arduino. (cellular data is irrelevant.. if you have the datam it can be written to/read from an SD card)
  • Not sure on this, I have never played with a NFC shiled/device before.
  • sure, some sort of mechanical solution. either digital lock or servo moving the lock device
  • Seems like the general RFID examples that comes with most RFID kits/set-ups..
Now, do these shields/devices 'conflict' with each other? all SPI? using same pins?
