I've been going through many tutorials to determine the value of the resistor i should use (using Ohm law, etc.) but I wanted to make sure I got it right.
According to my calculation, the resistor value is around 100 (Using a 5V power source), but since this is my first project I would like to make sure I got it right,
Thanks for taking the time for reading this and helping.
nordi:
...but I wanted to make sure I got it right.
Just make sure you don't get near the absolute max rating of the LED.
For tiny LEDs like that it might be 10-15mA. See the datasheet.
Or just use less than 10mA.
Those tiny LEDs are still very bright with 1mA.
Just use 1k for (5-2)*1k= 3mA.
10k (0.3mA) might still be too bright.
Leo..
The two different colours of LED need to be treated differently due to the different forward voltages:
2V orange and 3.3V blue.
For 20mA at 5V that means 150 ohms for orange, 82 ohms for blue. Scale up for lower currents.
You'll need enough pcb copper to dissipate the heat, note, if running them at full power, because they
are so small. Another reason to scale down the current.
So if your power source is 5V and LED Vf is 2V and you want, say, 5mA passing through it:
(5-3)/.005 = 400 ohms
Thank you very much, now I understand even better how to use the formula !
MarkT:
Please correct me if I'm wrong but my idea was to use one resistor for both colors (using a value strong enough for both):
I have an atmega328p-au (SMD), pin 1 is linked to the blue color, pin 2 to orange color and my idea was to have both pin 1 and 2 connected to the resistor, and said resistor is connected to both the blue and orange lead of the LED.
Since both colors are not on at the same time it would allow me to save space and components.
