Right values on HTS221 after pressing the reset bottom
Hey there,
I have this problem that, only after i press the reset bottom, the values of the HTS221 sensor goes to "normal values"
Any thing that i can do to solve it?
#include <SPI.h>
#include <SD.h>
#include "bar_temp_sensor.h"
//#include "gyro_mag_acc_sensor.h"
#include "hum_temp_sensor.h"
const int CS_PIN = 10;
  BARO.begin();
  HTS.begin();
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(CS_PIN))
  Serial.println("initialization failed!");
  while (1);
  Serial.println("initialization done.");
    readbar();
   //read_gyro_mag_acc();
    read_hum_temp();
#ifndef hum_temp_h
#define hum_temp_h
#include <SPI.h>
#include <SD.h>
#include <Arduino_HTS221.h>// Humadity and Temp Sensor
File temphum;
void read_hum_temp() {
  temphum = SD.open("temphum.txt", FILE_WRITE);
  Serial.print("Writing to temphum.txt...");
  if(temphum){
  float temperature = HTS.readTemperature();
  float humidity    = HTS.readHumidity();
  temphum.print("Temperature = ");
  temphum.print(temperature);
  temphum.println(" °C");
  Serial.print("Temperature = ");
  Serial.print(temperature);
  Serial.println(" C");
  temphum.print("Humidity    = ");
  temphum.print(humidity);
  temphum.println(" %");
  temphum.println();
  Serial.print("Humidity    = ");
  Serial.print(humidity);
  Serial.println(" %");
  Serial.print ("Writing done temphum!");
  temphum.close();
#endif
Thanks
Where is readbar() defined?
Does it work if you comment out all code lines relating to the SD card?
Is define in the file below
#ifndef bar_temp_sensor_h
#define bar_temp_sensor_h
#include <SPI.h>
#include <SD.h>
#include <Arduino_LPS22HB.h>
File baro;
void readbar() {
  baro = SD.open("baro.txt", FILE_WRITE);
   Serial.print("Writing to baro.txt...");
     if (baro){
     float pressure = BARO.readPressure();
     float temperature = BARO.readTemperature();
     baro.print("Pressure = ");
     baro.print(pressure);
     baro.println(" kPa");
     baro.print("Temperature = ");
     baro.print(temperature);
     baro.println(" C");
   Serial.print ("Writing done baro!");
   baro.close();
#endif
And yes they work all fine, without the SD card code lines
