Ring (accelerometer + LDR + XBee)
Hello everyone!
I need to develop a ring (actually, can be also a 2-finger ring), to measure light changes and accelerations, and then send the accelerometer data info to a computer in order to use that in LabView. The process would be something like:
1- When the LDR detects that the light is low, enable the accelerometer data adquisition, and send that data to the computer using XBee.
2- When the LDR detects that the light is high again, turn off the accelerometer.
My questions are related with the power compsumition of all the systems. How can I provide enough power for all the circuits, a 3V button cell would be enough? How much time do you think this system can run without changing the battery?
Thanks in advance!!! :slight_smile:
Why? Did you mean stop sending data, instead?
Less than 5 minutes. The XBee is the biggest power consumer in the mix. It will deplete your tiny battery in nothing flat.
PaulS:
Yes, sorry!
PaulS:
Wow, that's horrible :frowning: Any ideas how can I improve that? maybe it's a good idea to have a phone battery in the top of the hand? Or maybe are other wireless transmitting devices with less power compsumition?
Thanks again!
As long as it's a real battery, yes.
Some clue as to what you are really trying to accomplish might be useful.
PaulS:
I'll try to explain: In one industrial process, one manual operation is joining together two pieces. In the moment of the clipping, there are a small acceleration of the fingers. I want to detect that acceleration and send it to the computer in order to detect if the clipping has been correctly done or not. That's why I need to send the data wiressly, and has to be as light and low power as possible :~
