RIOT on Arduino Due
I'm trying to use RIOT (riot-os.org) on the Due, and I'm able to compile everything and flash it and it also produces some text in a terminal.
However when I try to use the default example included, I'm unable to get to a shell like it says in the documentation. If I compile for native (run on pc) then I get the shell.
In the documentation they suggest using
shell_init(&shell, NULL, UART0_BUFSIZE, uart0_readc, uart0_putchar);
for initialising the shell. But that doesn't work either, so I figured I would try
while (1) { uart0_putchar(uart0_readc()); }
Which doesn't produce any feedback either. However while (1) { uart0_putchar(0x41); } does output a lot of A's.
Does anybody know what could be wrong?
the riot-os.org site mentions a developer mailing list - suspect that's the place to
look for answers about the RIOT OS...
Yes, of course.
I ended up getting help on their IRC channel.
The solution was to merge this
Suspect it will become part of the master branch later on.
