ho provato a caricare lo sketch per il telescopio e questo è il risultato
vrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/macuser/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/macuser/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.de
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/n8/p3f2zqfx2w3dydrm22qtfwhr0000gn/T/arduino_build_402163/AstroFocus.ino.hex"
avrdude: writing flash (8690 bytes):
Writing | ################################################## | 100% 4.15s
avrdude: 8690 bytes of flash written
avrdude: verifying flash memory against /var/folders/n8/p3f2zqfx2w3dydrm22qtfwhr0000gn/T/arduino_build_402163/AstroFocus.ino.hex:
avrdude: load data flash data from input file /var/folders/n8/p3f2zqfx2w3dydrm22qtfwhr0000gn/T/arduino_build_402163/AstroFocus.ino.hex:
avrdude: input file /var/folders/n8/p3f2zqfx2w3dydrm22qtfwhr0000gn/T/arduino_build_402163/AstroFocus.ino.hex contains 8690 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.58s
avrdude: verifying ...
avrdude: 8690 bytes of flash verified
avrdude done. Thank you.
