(RISOLTO)aiuto nel collegare due sketch
buon giorno a tutti chiedo il vostro aiuto nell unire 2 sketch funzionanti singolarmente ma al contrario quando provo ad unirli.
questi sono i due codice
#include <SoftwareSerial.h>
#include <Wire.h>
#include <RTClib.h>
#define BT_TX_PIN  1
#define BT_RX_PIN  0
SoftwareSerial mySerial(BT_TX_PIN, BT_RX_PIN);
RTC_DS1307 RTC;
LiquidCrystal_I2C lcd(0x27,16,2);
char lettera;    //inizializzo carattere
char buffer[16];
String voice;
byte rele1=6;
byte rele2=7;
byte rele3=8;
byte rele4=9;
byte rele5=13;
byte rele6=12;
byte rele7=11;
byte rele8=10;
int previousSec = 0;
int stato;
uint8_t SPENTO[8] = {0x0E, 0x11, 0x11, 0x11, 0x0A, 0x0E, 0x0E, 0x04,};
uint8_t ACCESO[8] = {0x0E, 0x1F, 0x1F, 0x1F, 0x0E, 0x0E, 0x0E, 0x04,};
void accenditutto() {
  digitalWrite (rele1, LOW);
  digitalWrite (rele2, LOW);
  digitalWrite (rele3, LOW);
  digitalWrite (rele4, LOW);
void spegnitutto() {
  digitalWrite (rele1, HIGH);
  digitalWrite (rele2, HIGH);
  digitalWrite (rele3, HIGH);
  digitalWrite (rele4, HIGH);
void accendilampada() {
  Serial.println("relay 1 off");
  viewSocket( 1,false );
void spegnilampada() {
  Serial.println("relay 1 on");
  viewSocket( 1,true );
void accendiflipper() {
  Serial.println("relay 2 off");
  viewSocket( 2,false );
void spegniflipper() {
  Serial.println("relay 2 on");
  viewSocket( 2,true );
void accenditv() {
  Serial.println("relay 3 off");
  viewSocket( 3,false );
void spegnitv() {
  Serial.println("relay 3 on");
  viewSocket( 3,true );
  lcd.backlight();
    mySerial.begin(9600);
    Wire.begin();
    RTC.begin();
    lcd.init();
    pinMode(rele1, OUTPUT);
    pinMode(rele2, OUTPUT);
    pinMode(rele3, OUTPUT);
    pinMode(rele4, OUTPUT);
    pinMode(rele5, OUTPUT);
    pinMode(rele6, OUTPUT);
    pinMode(rele7, OUTPUT);
    pinMode(rele8, OUTPUT);
    digitalWrite(rele1, HIGH);
    digitalWrite(rele2, HIGH);
    digitalWrite(rele3, HIGH);
    digitalWrite(rele4, HIGH);
    digitalWrite(rele5, HIGH);
    digitalWrite(rele6, HIGH);
    digitalWrite(rele7, HIGH);
    digitalWrite(rele8, HIGH);
    if (! RTC.isrunning()) {
      Serial.println("RTC is NOT running!");
      RTC.adjust(DateTime(__DATE__, __TIME__));
    lcd.createChar(0, SPENTO);
    lcd.createChar(1, ACCESO);
    lcd.setCursor (0, 0);
    lcd.print("Ciabatta BT v.2");
    delay(2000);
    lcd.clear();
    lcd.setCursor (12, 0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
while(Serial.available()) {
    delay(10);
    char c=Serial.read();
    if(c=='#')
    {break; }
    voice += c;
if (voice.length() > 0) {
  Serial.println(voice);
  if (voice == "*accendi tutto")
  {accenditutto() ; }
  else if (voice == "*spegni tutto")
  {spegnitutto() ; }
  else if (voice == "*accendi lampada")
  {accendilampada() ; }
  else if (voice == "*spegni lampada")
  {spegnilampada() ; }
  else if (voice == "*accendi flipper")
  {accendiflipper() ; }
  else if (voice == "*spegni flipper")
  {spegniflipper() ; }
  else if (voice == "*accendi tv")
  {accenditv() ; }
  else if (voice == "*spegni tv")
  {spegnitv() ; }
voice="";
  DateTime now = RTC.now();
  if(now.second() != previousSec) {
        lcd.setCursor( 0,0 );
        sprintf(buffer,  "%02d:%02d:%02d", now.hour(), now.minute(), now.second());
        lcd.print( buffer );
        previousSec = now.second();
    if(mySerial.available()) { // se il serial buffer contiene almeno un carattere
        lettera = mySerial.read(); // leggi il buffer
        switch (lettera) {
        case 'A':
            digitalWrite(rele1, LOW); // eccita il relay1
            digitalWrite(rele1, HIGH); // diseccita il relay1
        case 'S':
        case 'Q':
            digitalWrite(rele2, LOW); // eccita il relay2
        case 'W':
            digitalWrite(rele2, HIGH); // diseccita il relay2
        case 'E':
            digitalWrite(rele3, LOW); // eccita il relay3
        case 'R':
            digitalWrite(rele3, HIGH); // diseccita il relay3
        case 'T':
            digitalWrite(rele4, LOW); // eccita il relay4
            Serial.println("relay 4 on");
            viewSocket( 4,true );
        case 'Y':
            digitalWrite(rele4, HIGH); // diseccita il relay4
            Serial.println("relay 4 off");
            viewSocket( 4,false );
        case 'U':
            digitalWrite(rele5, LOW); // eccita il relay5
            Serial.println("relay 5 on");
            viewSocket( 5,true );
        case 'I':
            digitalWrite(rele5, HIGH); // diseccita il relay5
            Serial.println("relay 5 off");
            viewSocket( 5,false );
        case 'O':
            digitalWrite(rele6, LOW); // eccita il relay6
            Serial.println("relay 6 on");
            viewSocket( 6,true );
        case 'P':
            digitalWrite(rele6, HIGH); // diseccita il relay6
            Serial.println("relay 6 off");
            viewSocket( 6,false );
        case 'D':
            digitalWrite(rele7, LOW); // eccita il relay7
            Serial.println("relay 7 on");
            viewSocket( 7,true );
        case 'F':
            digitalWrite(rele7, HIGH); // diseccita il relay7
            Serial.println("relay 7 off");
            viewSocket( 7,false );
        case 'G':
            digitalWrite(rele8, LOW); // eccita il relay8
            Serial.println("relay 8 on");
            viewSocket( 8,true );
        case 'H':
            digitalWrite(rele8, HIGH); // diseccita il relay8
            Serial.println("relay 8 off");
            viewSocket( 8,false );
void viewSocket(byte num, boolean status) {
  lcd.setCursor( ( 11+num ),0 );
  if ( status ) {
     lcd.write(1);
     lcd.setCursor ( 0,1 );
     lcd.print("Acceso rele ");
    lcd.write(0);
    lcd.print("Spento rele ");
  lcd.setCursor ( 12,1 );
  lcd.print(num);
Cosa c'e' di collegato ad Arduino e come ? Quale Arduino ? Uno, Mega, Leonardo ?
P.S. per diminuire l'uso della SRAM metti const ai pin, ovvero const byte rele1=6;
e questo il secondo codice
int rele1 = 6;
int rele2 = 7;
int rele3 = 8;
int rele4 = 9;
int rele5 = 10;
int rele6 = 11;
int rele7 = 12;
int rele8 = 13;
int stato;
  stato = Serial.read();
  if(stato =='A') {
  }else if (stato =='S'){
  }if(stato =='Q') {
  }else if (stato =='W'){
  }if(stato =='E') {
  }else if (stato =='R'){
  }if(stato =='T') {
  }else if (stato =='Y'){
  }if(stato =='U') {
  }else if (stato =='I'){
  }if(stato =='O') {
  }else if (stato =='P'){
  }if(stato =='D') {
  }else if (stato =='F'){
  }if(stato =='G') {
  }else if (stato =='H'){
  }else if (stato =='J'){
  digitalWrite(rele1,HIGH);
  digitalWrite(rele2,HIGH);
  digitalWrite(rele3,HIGH);
  digitalWrite(rele4,HIGH);
  digitalWrite(rele5,HIGH);
  digitalWrite(rele6,HIGH);
  digitalWrite(rele7,HIGH);
  digitalWrite(rele8,HIGH);
adesso prendendo i vari codici singolarmenti tutti e due funzionano, il primo per il controllo tramite bluetooth e il secondo cod. per il controllo tramite pc, ma quando vado ad unirli il secondo non funziona.
mi potete aiutare a capire dovè l errore?
grazie mille
Nel primo codice usi la SoftwareSerial ma usi COMUNQUE i pin 0 e 1 che sono quelli della seriale fisica, ovvero della USB. Se metti il modulo BT su quei pin ti sei fregato la connessione usb/pc.
quindi dovrei spostare i pin rx e tx del modulo bluetooth
ps. il tutto è tramite arduino uno
ragazzi non so come ho sostituito "byte" con "int" e spostato i pin del modulo bluetooth e adesso tutto funziona, riesco a controllare i relè sia tramite bluetooth che tramite il mio programma vb.net
Tieni conto che ora le Serial.println("relay 3 on"); andranno sulla seriale e non attraverso il BT
La const byte rele1=6; invece di int rele1=6; diminuisce solo la memoria occupata, nulla più
