[RISOLTO] Convertire in millis()
Ciao a tutti, mi potreste aiutare a tradurre questo codice in millis()...
Grazie
#define RELE1   5
#define RELE2   2
void setup(){
  pinMode(RELE1, OUTPUT);
  pinMode(RELE2, OUTPUT);
void loop(){
  digitalWrite(RELE1, 0);
  digitalWrite(RELE1, 1);
  digitalWrite(RELE2, 0);
  delay(1500);
  digitalWrite(RELE2, 1);
Lo schitto in questo modo ma non funziona xkè?
const int rele1 =  5;
const int rele2 =  2;
int releState1 = LOW;
int releState2 = LOW;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
const long interval1 = 500;
const long interval2 = 1500;
  pinMode(rele1, OUTPUT);
  if(currentMillis - previousMillis1 >= interval1) {
    previousMillis1 = currentMillis;
    if (releState1 == LOW)
      releState1 = HIGH;
      releState1 = LOW;
    digitalWrite(rele1, releState1);
  if(currentMillis - previousMillis2 >= interval2) {
    previousMillis2 = currentMillis;
    if (releState2 == LOW)
      releState2 = HIGH;
      releState2 = LOW;
    digitalWrite(rele2, releState2);
ciao, io ci sono riuscito con questo esempio.
const int buttonPin1 = 8;     // the number of the pushbutton pin
const int buttonPin2 = 9;
const int ledPin1 =  4;  // the number of the LED pin
const int ledPin2 =  5;
unsigned long off_time1;
unsigned long off_time2;
boolean ledState1=false;
boolean ledState2=false;
int buttonState1 = 0;    // variable for reading the pushbutton status
int buttonState2 = 0;
  // initialize the LED pin as an output:
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  digitalWrite(ledPin1, LOW);
  digitalWrite(ledPin2, LOW);
void loop(){
if ((ledState1) && (millis()>=off_time1)) /* is it on and is it later or equal to off_time */
    digitalWrite(ledPin1,HIGH);
    ledState1 = false;
else if (!ledState1) /* is it off? */
    buttonState1 = digitalRead(buttonPin1);
    if(buttonState1 == LOW)
        digitalWrite(ledPin1, HIGH);
        ledState1 = true;
        off_time1 = millis() + 20000;
if (buttonState1==HIGH && buttonState2==HIGH)
  digitalWrite(ledPin1,LOW);
  digitalWrite(ledPin2,LOW);
 // off_time = millis() + 0;
if ((ledState2) && (millis()>=off_time2)) /* is it on and is it later or equal to off_time */
    digitalWrite(ledPin2,HIGH);
    ledState2 = false;
else if (!ledState2) /* is it off? */
    buttonState2 = digitalRead(buttonPin2);
    if(buttonState2 == LOW)
        digitalWrite(ledPin2, HIGH);
        ledState2 = true;
        off_time2 = millis() + 20000;
