Grazie
Ma ancora no
Quello che non capisco che ho ripreso questo progetto dopo averlo lasciato funzionante nel cassetto
Collegamenti controllati e tutti saldati niente ossidazioni
Allego le librerie
#include "AS726X.h"
#include "Arduino.h"
//Sets up the sensor for constant read
//Returns the sensor version (AS7262 or AS7263)
AS726X::AS726X()
//void AS726X::begin(TwoWire &wirePort, byte gain, byte measurementMode, byte SET_BULB_CURRENT, byte I_TIME)
void AS726X::begin(TwoWire &wirePort, byte gain, byte measurementMode)
_i2cPort = &wirePort;
_i2cPort->begin();
//Serial.begin(SERIAL);
_sensorVersion = virtualReadRegister(AS726x_HW_VERSION);
if (_sensorVersion != 0x3E && _sensorVersion != 0x3F) //HW version for AS7262 and AS7263
Serial.print("ID (should be 0x3E or 0x3F): 0x");
Serial.println(_sensorVersion, HEX);
// setBulbCurrent(SET_BULB_CURRENT); //Set to 0b00 12.5mA (minimum)
setBulbCurrent(0b00); //Set to 0b00 12.5mA (minimum)
disableBulb(); //Turn off to avoid heating the sensor
setIndicatorCurrent(0b11); //Set to 8mA (maximum)
disableIndicator(); //Turn off lights to save power
// setIntegrationTime(I_TIME); //I_TIME * 2.8ms, 50 * 2 .8ms = 140ms. 0 to 255 is valid.
setIntegrationTime(50); //50 * 2 .8ms = 140ms. 0 to 255 is valid
//If you use Mode 2 or 3 (all the colors) then integration time is double. 140*2 = 280ms between readings.
setGain(gain); //Set gain to 64x
setMeasurementMode(measurementMode); //One-shot reading of VBGYOR
if (_sensorVersion == 0)
Serial.println("Sensor failed to respond. Check wiring.");
while (1); //Freeze!
if (_sensorVersion == SENSORTYPE_AS7262) Serial.println("AS7262 online!");
if (_sensorVersion == SENSORTYPE_AS7263) Serial.println("AS7263 online!");
//Sets the measurement mode
//Mode 0: Continuous reading of VBGY (7262) / STUV (7263)
//Mode 1: Continuous reading of GYOR (7262) / RTUX (7263)
//Mode 2: Continuous reading of all channels (power-on default)
//Mode 3: One-shot reading of all channels
void AS726X::setMeasurementMode(byte mode)
if (mode > 0b11) mode = 0b11;
//Read, mask/set, write
byte value = virtualReadRegister(AS726x_CONTROL_SETUP); //Read
value &= 0b11110011; //Clear BANK bits
value |= (mode << 2); //Set BANK bits with user's choice
virtualWriteRegister(AS726x_CONTROL_SETUP, value); //Write
//Sets the gain value
//Gain 0: 1x (power-on default)
//Gain 1: 3.7x
//Gain 2: 16x
//Gain 3: 64x
void AS726X::setGain(byte gain)
if (gain > 0b11) gain = 0b11;
value &= 0b11001111; //Clear GAIN bits
value |= (gain << 4); //Set GAIN bits with user's choice
//Sets the integration value
//Give this function a byte from 0 to 255.
//Time will be 2.8ms * [integration value]
void AS726X::setIntegrationTime(byte integrationValue)
virtualWriteRegister(AS726x_INT_T, integrationValue); //Write
void AS726X::enableInterrupt()
value |= 0b01000000; //Set INT bit
//Disables the interrupt pin
void AS726X::disableInterrupt()
value &= 0b10111111; //Clear INT bit
//Prints all measurements
void AS726X::printMeasurements()
//Visible readings
Serial.print(" Reading: V[");
Serial.print(getCalibratedViolet(), 2);
Serial.print("] B[");
Serial.print(getCalibratedBlue(), 2);
Serial.print("] G[");
Serial.print(getCalibratedGreen(), 2);
Serial.print("] Y[");
Serial.print(getCalibratedYellow(), 2);
Serial.print("] O[");
Serial.print(getCalibratedOrange(), 2);
Serial.print("] R[");
Serial.print(getCalibratedRed(), 2);
else if (_sensorVersion == SENSORTYPE_AS7263)
//Near IR readings
Serial.print("Reading: R[");
Serial.print(getCalibratedR(), 2);
Serial.print("], S[");
Serial.print(getCalibratedS(), 2);
Serial.print("], T[");
Serial.print(getCalibratedT(), 2);
Serial.print("], U[");
Serial.print(getCalibratedU(), 2);
Serial.print("], V[");
Serial.print(getCalibratedV(), 2);
Serial.print("], W[");
Serial.print(getCalibratedW(), 2);
float tempF = getTemperatureF();
// Serial.print("], tempF[");
// Serial.print(tempF, 1);
// Serial.print("]");
float tempC = ( tempF - 32.0 ) * 100.0 / 180.0;
Serial.print("], tempC[");
Serial.print(tempC, 1);
Serial.print("]");
void AS726X::printUncalibratedMeasurements()
//Visible readings
Serial.print(getViolet(), 2);
Serial.print(getBlue(), 2);
Serial.print(getGreen(), 2);
Serial.print(getYellow(), 2);
Serial.print(getOrange(), 2);
Serial.print(getRed(), 2);
//Near IR readings
Serial.print(" Reading: R[");
Serial.print(getR(), 2);
Serial.print("] S[");
Serial.print(getS(), 2);
Serial.print("] T[");
Serial.print(getT(), 2);
Serial.print("] U[");
Serial.print(getU(), 2);
Serial.print("] V[");
Serial.print(getV(), 2);
Serial.print("] W[");
Serial.print(getW(), 2);
Serial.print("] tempF[");
Serial.print("]");
//Tells IC to take measurements and polls for data ready flag
void AS726X::takeMeasurements()
clearDataAvailable(); //Clear DATA_RDY flag when using Mode 3
//Goto mode 3 for one shot measurement of all channels
setMeasurementMode(3);
//Wait for data to be ready
while (dataAvailable() == false) delay(POLLING_DELAY);
//Readings can now be accessed via getViolet(), getBlue(), etc
//Turns on bulb, takes measurements, turns off bulb
void AS726X::takeMeasurementsWithBulb()
//enableIndicator(); //Tell the world we are taking a reading.
//The indicator LED is red and may corrupt the readings
enableBulb(); //Turn on bulb to take measurement
takeMeasurements();
disableBulb(); //Turn off bulb to avoid heating sensor
//disableIndicator();
//Get the various color readings
int AS726X::getViolet() {
return (getChannel(AS7262_V));
int AS726X::getBlue() {
return (getChannel(AS7262_B));
int AS726X::getGreen() {
return (getChannel(AS7262_G));
int AS726X::getYellow() {
return (getChannel(AS7262_Y));
int AS726X::getOrange() {
return (getChannel(AS7262_O));
int AS726X::getRed() {
return (getChannel(AS7262_R));
//Get the various NIR readings
int AS726X::getR() {
return (getChannel(AS7263_R));
int AS726X::getS() {
return (getChannel(AS7263_S));
int AS726X::getT() {
return (getChannel(AS7263_T));
int AS726X::getU() {
return (getChannel(AS7263_U));
int AS726X::getV() {
return (getChannel(AS7263_V));
int AS726X::getW() {
return (getChannel(AS7263_W));
//A the 16-bit value stored in a given channel registerReturns
int AS726X::getChannel(byte channelRegister)
int colorData = virtualReadRegister(channelRegister) << 8; //High byte
colorData |= virtualReadRegister(channelRegister + 1); //Low byte
return (colorData);
//Returns the various calibration data
float AS726X::getCalibratedViolet() {
return (getCalibratedValue(AS7262_V_CAL));
float AS726X::getCalibratedBlue() {
return (getCalibratedValue(AS7262_B_CAL));
float AS726X::getCalibratedGreen() {
return (getCalibratedValue(AS7262_G_CAL));
float AS726X::getCalibratedYellow() {
return (getCalibratedValue(AS7262_Y_CAL));
float AS726X::getCalibratedOrange() {
return (getCalibratedValue(AS7262_O_CAL));
float AS726X::getCalibratedRed() {
return (getCalibratedValue(AS7262_R_CAL));
float AS726X::getCalibratedR() {
return (getCalibratedValue(AS7263_R_CAL));
float AS726X::getCalibratedS() {
return (getCalibratedValue(AS7263_S_CAL));
float AS726X::getCalibratedT() {
return (getCalibratedValue(AS7263_T_CAL));
float AS726X::getCalibratedU() {
return (getCalibratedValue(AS7263_U_CAL));
float AS726X::getCalibratedV() {
return (getCalibratedValue(AS7263_V_CAL));
float AS726X::getCalibratedW() {
return (getCalibratedValue(AS7263_W_CAL));
//Given an address, read four bytes and return the floating point calibrated value
float AS726X::getCalibratedValue(byte calAddress)
byte b0, b1, b2, b3;
b0 = virtualReadRegister(calAddress + 0);
b1 = virtualReadRegister(calAddress + 1);
b2 = virtualReadRegister(calAddress + 2);
b3 = virtualReadRegister(calAddress + 3);
//Channel calibrated values are stored big-endian
uint32_t calBytes = 0;
calBytes |= ((uint32_t)b0 << (8 * 3));
calBytes |= ((uint32_t)b1 << (8 * 2));
calBytes |= ((uint32_t)b2 << (8 * 1));
calBytes |= ((uint32_t)b3 << (8 * 0));
return (convertBytesToFloat(calBytes));
//Given 4 bytes returns the floating point value
float AS726X::convertBytesToFloat(uint32_t myLong)
float myFloat;
memcpy(&myFloat, &myLong, 4); //Copy bytes into a float
return (myFloat);
//Checks to see if DRDY flag is set in the control setup register
boolean AS726X::dataAvailable()
return (value & (1 << 1)); //Bit 1 is DATA_RDY
//Clears the DRDY flag
//Normally this should clear when data registers are read
boolean AS726X::clearDataAvailable()
value &= ~(1 << 1); //Set the DATA_RDY bit
//Enable the onboard indicator LED
void AS726X::enableIndicator()
byte value = virtualReadRegister(AS726x_LED_CONTROL);
value |= (1 << 0); //Set the bit
virtualWriteRegister(AS726x_LED_CONTROL, value);
//Disable the onboard indicator LED
void AS726X::disableIndicator()
value &= ~(1 << 0); //Clear the bit
//Set the current limit of onboard LED. Default is max 8mA = 0b11.
void AS726X::setIndicatorCurrent(byte current)
if (current > 0b11) current = 0b11;
byte value = virtualReadRegister(AS726x_LED_CONTROL); //Read
value &= 0b11111001; //Clear ICL_IND bits
value |= (current << 1); //Set ICL_IND bits with user's choice
virtualWriteRegister(AS726x_LED_CONTROL, value); //Write
//Enable the onboard 5700k or external incandescent bulb
void AS726X::enableBulb()
value |= (1 << 3); //Set the bit
//Disable the onboard 5700k or external incandescent bulb
void AS726X::disableBulb()
value &= ~(1 << 3); //Clear the bit
//Set the current limit of bulb/LED.
//Current 0: 12.5mA
//Current 1: 25mA
//Current 2: 50mA
//Current 3: 100mA
void AS726X::setBulbCurrent(byte current)
if (current > 0b11) current = 0b11; //Limit to two bits
value &= 0b11001111; //Clear ICL_DRV bits
value |= (current << 4); //Set ICL_DRV bits with user's choice
//Returns the temperature in C
//Pretty inaccurate: +/-8.5C
byte AS726X::getTemperature()
return (virtualReadRegister(AS726x_DEVICE_TEMP));
//Convert to F if needed
float AS726X::getTemperatureF()
float temperatureF = getTemperature();
temperatureF = temperatureF * 1.8 + 32.0;
return (temperatureF);
//Does a soft reset
//Give sensor at least 1000ms to reset
void AS726X::softReset()
value |= (1 << 7); //Set RST bit
//Read a virtual register from the AS726x
byte AS726X::virtualReadRegister(byte virtualAddr)
byte status;
//Do a prelim check of the read register
status = readRegister(AS72XX_SLAVE_STATUS_REG);
if ((status & AS72XX_SLAVE_RX_VALID) != 0) //There is data to be read
//Serial.println("Premptive read");
byte incoming = readRegister(AS72XX_SLAVE_READ_REG); //Read the byte but do nothing with it
//Wait for WRITE flag to clear
while (1)
if ((status & AS72XX_SLAVE_TX_VALID) == 0) break; // If TX bit is clear, it is ok to write
// Send the virtual register address (bit 7 should be 0 to indicate we are reading a register).
writeRegister(AS72XX_SLAVE_WRITE_REG, virtualAddr);
//Wait for READ flag to be set
while (1)
if ((status & AS72XX_SLAVE_RX_VALID) != 0) break; // Read data is ready.
return (incoming);
//Write to a virtual register in the AS726x
void AS726X::virtualWriteRegister(byte virtualAddr, byte dataToWrite)
byte status;
//Wait for WRITE register to be empty
while (1)
if ((status & AS72XX_SLAVE_TX_VALID) == 0) break; // No inbound TX pending at slave. Okay to write now.
// Send the virtual register address (setting bit 7 to indicate we are writing to a register).
writeRegister(AS72XX_SLAVE_WRITE_REG, (virtualAddr | 0x80));
while (1)
// Send the data to complete the operation.
writeRegister(AS72XX_SLAVE_WRITE_REG, dataToWrite);
//Reads from a give location from the AS726x
byte AS726X::readRegister(byte addr)
_i2cPort->beginTransmission(AS726X_ADDR);
_i2cPort->write(addr);
_i2cPort->endTransmission();
_i2cPort->requestFrom(AS726X_ADDR, 1);
if (_i2cPort->available()) {
return (_i2cPort->read());
else {
Serial.println("I2C Error");
return (0xFF); //Error
//Write a value to a spot in the AS726x
void AS726X::writeRegister(byte addr, byte val)
_i2cPort->write(val);
Created: 7/11/2017 12:06:22 PM
Author: andrew.england
Editor: http://www.visualmicro.com
#ifndef _AS726X_h
#define _AS726X_h
#include "Wire.h"
class AS726X {
public:
AS726X();
void begin(TwoWire &wirePort = Wire, byte gain = 3, byte measurementMode = 3);
//void begin(TwoWire &wirePort = Wire, byte gain = 3, byte //measurementMode = 3, byte SET_BULB_CURRENT = 0, byte I_TIME //= 50);
void takeMeasurements();
void takeMeasurementsWithBulb();
void printMeasurements();
void printUncalibratedMeasurements();
byte getTemperature();
float getTemperatureF();
void setMeasurementMode(byte mode);
boolean dataAvailable();
void enableIndicator();
void disableIndicator();
void setIndicatorCurrent(byte current);
void enableBulb();
void disableBulb();
void setBulbCurrent(byte current);
void softReset();
void setGain(byte gain);
void setIntegrationTime(byte integrationValue);
void enableInterrupt();
void disableInterrupt();
int getViolet();
int getBlue();
int getGreen();
int getYellow();
int getOrange();
int getRed();
int getR();
int getS();
int getT();
int getU();
int getV();
int getW();
float getCalibratedViolet();
float getCalibratedBlue();
float getCalibratedGreen();
float getCalibratedYellow();
float getCalibratedOrange();
float getCalibratedRed();
float getCalibratedR();
float getCalibratedS();
float getCalibratedT();
float getCalibratedU();
float getCalibratedV();
float getCalibratedW();
private:
TwoWire *_i2cPort;
int getChannel(byte channelRegister);
float getCalibratedValue(byte calAddress);
float convertBytesToFloat(uint32_t myLong);
boolean clearDataAvailable();
byte virtualReadRegister(byte virtualAddr);
void virtualWriteRegister(byte virtualAddr, byte dataToWrite);
void writeRegister(byte addr, byte val);
byte readRegister(byte addr);
#define AS726X_ADDR 0x49 //7-bit unshifted default I2C Address
#define SENSORTYPE_AS7262 0x3E
#define SENSORTYPE_AS7263 0x3F
//Register addresses
#define AS726x_DEVICE_TYPE 0x00
#define AS726x_HW_VERSION 0x01
#define AS726x_CONTROL_SETUP 0x04
#define AS726x_INT_T 0x05
#define AS726x_DEVICE_TEMP 0x06
#define AS726x_LED_CONTROL 0x07
#define AS72XX_SLAVE_STATUS_REG 0x00
#define AS72XX_SLAVE_WRITE_REG 0x01
#define AS72XX_SLAVE_READ_REG 0x02
//The same register locations are shared between the AS7262 and AS7263, they're just called something different
//AS7262 Registers
#define AS7262_V 0x08
#define AS7262_B 0x0A
#define AS7262_G 0x0C
#define AS7262_Y 0x0E
#define AS7262_O 0x10
#define AS7262_R 0x12
#define AS7262_V_CAL 0x14
#define AS7262_B_CAL 0x18
#define AS7262_G_CAL 0x1C
#define AS7262_Y_CAL 0x20
#define AS7262_O_CAL 0x24
#define AS7262_R_CAL 0x28
//AS7263 Registers
#define AS7263_R 0x08
#define AS7263_S 0x0A
#define AS7263_T 0x0C
#define AS7263_U 0x0E
#define AS7263_V 0x10
#define AS7263_W 0x12
#define AS7263_R_CAL 0x14
#define AS7263_S_CAL 0x18
#define AS7263_T_CAL 0x1C
#define AS7263_U_CAL 0x20
#define AS7263_V_CAL 0x24
#define AS7263_W_CAL 0x28
#define AS72XX_SLAVE_TX_VALID 0x02
#define AS72XX_SLAVE_RX_VALID 0x01
#define POLLING_DELAY 5 //Amount of ms to wait between checking for virtual register changes
byte _sensorVersion = 0;
#endif
