Salve a tutti , ho acquistato un sensore di temperatura DS18B20, l’ ho collegato all’ arduino seguendo questo schema :
ho caricato sull’ arduino questo sketch che utilizza la libreria OneWire e la libreria DallasTemperature :
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress insideThermometer;
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// locate devices on the bus
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// assign address manually. the addresses below will beed to be changed
// to valid device addresses on your bus. device address can be retrieved
// by using either oneWire.search(deviceAddress) or individually via
// sensors.getAddress(deviceAddress, index)
//insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
// Method 1:
// search for devices on the bus and assign based on an index. ideally,
// you would do this to initially discover addresses on the bus and then
// use those addresses and manually assign them (see above) once you know
// the devices on your bus (and assuming they don't change).
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
// method 2: search()
// search() looks for the next device. Returns 1 if a new address has been
// returned. A zero might mean that the bus is shorted, there are no devices,
// or you have already retrieved all of them. It might be a good idea to
// check the CRC to make sure you didn't get garbage. The order is
// deterministic. You will always get the same devices in the same order
// Must be called before search()
//oneWire.reset_search();
// assigns the first address found to insideThermometer
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
// method 1 - slower
//Serial.print("Temp C: ");
//Serial.print(sensors.getTempC(deviceAddress));
//Serial.print(" Temp F: ");
//Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
// method 2 - faster
float tempC = sensors.getTempC(deviceAddress);
Serial.print(tempC);
Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// It responds almost immediately. Let's print out the data
printTemperature(insideThermometer); // Use a simple function to print out the data
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
Come potete vedere dal log della seriale il sensore non viene riconosciuto :
Requesting temperatures...Dallas Temperature IC Control Library Demo
Locating devices...Found 0 devices.
Parasite power is: OFF
Device 0 Address: 0000000000000000
Device 0 Resolution: 0
Requesting temperatures...DONE
Temp C: -127.00 Temp F: -196.60
Qualcuno ha qualche idea su come fare per risolvere ?
I collegamenti hardware sono corretti, la R sei sicuro che sia effettivamente da 4k7? Se fosse più bassa potrebbe bloccare il sensore su HIGH. Hai provato con un tester che i contatti siano garantiti? tante volte la pessima qualità dei fili e delle breadboard usate fa sì che un circuito non funzioni.
Nemmeno a me quel codice ha mai funzionato…
Io ho risolto con questo Funziona benissimo.
IDE 022.
Auguroni!
Trova indirizzo delle sonde DS18x20
Originale by TutorialPedia : http://tutorialpedia.org/tutorials/Working+with+Dallas+DS18S20+and+DS18B20+temperature+sensors+from+Arduino.html
Modifiche minori e traduzione in italiano
a cura di Bernardo Giovanni (http://www.settorezero.com)
// inizializza il bus onewire sulla porta n°10
OneWire ow(16);
void setup(void)
Serial.begin(9600); // inizializza la porta seriale a 9600
lookUpSensors(); // avvia la ricerca delle sonde di temperatura
void lookUpSensors()
byte address[8]; // questo array conterrà l'indirizzo delle sonde
int i=0;
byte ok = 0, tmp = 0;
// avvia la ricerca
Serial.println("--Ricerca avviata--");
while (ow.search(address))
tmp = 0;
// Se il primo byte dell'indirizzo è 0x10, si tratta di una sonda DS18S20
if (address[0] == 0x10)
Serial.println("A questo indirizzo si trova una DS18S20 : ");
tmp = 1; // ricerca andata a buon fine
// Se il primo byte dell'indirizzo è 0x28, si tratta di una sonda DS18B20
if (address[0] == 0x28)
Serial.println("A questo indirizzo si trova una DS18B20 : ");
// Se il flag tmp si trova a 1, mostro l'indirizzo
if (tmp == 1)
if (OneWire::crc8(address, 7) != address[7]) // faccio il controllo del CRC8
Serial.println(" (ma CRC8 non valido)");
// tutto ok, mostro l'indirizzo in formato esadecimale
for (i=0;i<8;i++)
Serial.print("0x");
if (address[i] < 9)
Serial.print("0");
Serial.print(address[i],HEX);
if (i<7)
Serial.print(",");
Serial.println("");
ok = 1;
} //end if tmp
}//end while
if (ok == 0)
Serial.println("Non ho trovato sonde di temperatura");
Serial.println("--Ricerca terminata--");
void loop(void)
// non faccio niente... ho fatto tutto nel setup!
risolto parzialmente, errore mio avevo (ri)montato male il sensore, il primo sketch rileva la sonda ma rileva esattamente la temperatura solo se il sensore è in parasite mode altrimenti rileva 127.50 C e 261.50 F lo sketch di DanielaES funziona perfettamente (ma rileva soltanto la presenza della sonda).Grazie dell' aiuto e auguri di buon anno a tutti.
encrypt:
lo sketch di DanielaES funziona perfettamente (ma rileva soltanto la presenza della sonda).Grazie dell’ aiuto e auguri di buon anno a tutti.
Una volta che hai l’indirizzo, devi utilizzare questo codice
Temperatura con Arduino e DS18S20
spunti per stazione meteo
original by Bernardo Giovanni (http://www.settorezero.com)
Funzioni per lettura DS18S20 prese da tutorialpedia:
float T; // Valore di temperatura in °C dalla sonda DS18S20
OneWire ONE_WIRE_BUS(10); // Bus One-Wire (sonda DS18S20) sul pin 10
// Indirizzo della sonda DS18S20
// Nota: trova l'indirizzo della tua sonda col programma precedente e incollalo al posto di questo
byte T_SENSOR[8] = {0x10,0x72,0x08,0xBA,0x01,0x08,0x00,0x64};
Serial.begin(9600); // Inizializzo la porta seriale
void writeTimeToScratchpad(byte* address)
ONE_WIRE_BUS.reset(); // Resetto il bus
ONE_WIRE_BUS.select(address); // Seleziono la mia sonda DS18S20
ONE_WIRE_BUS.write(0x44,1); // Richiamo la funzione di conversione temperatura (44h)
// che posiziona il valore di temperatura nello scratchpad (comando Convert T)
delay(1000); // Attendo un secondo che la scrittura sia completa
void readTimeFromScratchpad(byte* address, byte* data)
ONE_WIRE_BUS.write(0xBE); // Comando di lettura dello scratchpad (comando Read Scratchpad)
for (byte i=0;i<9;i++)
data[i] = ONE_WIRE_BUS.read(); // Leggo i 9 bytes che compongono lo scratchpad
float getTemperature(byte* address)
int tr;
byte data[12];
writeTimeToScratchpad(address); // Richiamo conversione temperatura
readTimeFromScratchpad(address,data); // effettuo la lettura dello Scratchpad
tr = data[0]; // Posiziono in TR il byte meno significativo
// il valore di temperatura è contenuto nel byte 0 e nel byte 1
// Il byte 1 contiene il segno
if (data[1] > 0x80) // Se il valore è >128 allora la temperatura è negativa
tr = !tr + 1; // Correzione per complemento a due
tr = tr * -1; // Ottengo il valore negativo
int cpc = data[7]; // Byte 7 dello scratchpad: COUNT PER °C (10h)
int cr = data[6]; // Byte 6 dello scratchpad: COUNT REMAIN (0Ch)
tr = tr >> 1; // Rilascio il bit 0 come specificato dal datasheet per avere una risoluzione > di 9bit
// Calcolo la temperatura secondo la formula fornita sul datasheet:
// TEMPERATURA = LETTURA - 0.25 + (COUNT PER °C - COUNT REMAIN)/(COUNT PER °C)
return tr - (float)0.25 + (cpc - cr)/(float)cpc;
// Conversione da Fahrenheit a Celsius
float f2c(float val)
float aux = val - 32;
return (aux * 5 / 9);
// COnversione da Celsius a Fahrenheit
float c2f(float val)
float aux = (val * 9 / 5);
return (aux + 32);
// Lettura temperatura (la DS18S20 fornisce il valore in °C)
T = getTemperature(T_SENSOR);
// Stampo i risultati su terminale seriale
Serial.print("Temperatura: ");
Serial.print(T,1); // Scrivo il valore di temperatura con un decimale
Serial.println(" C");
// Attendo 1 secondi per ricominciare
