Ciao,
Vorrei che il blink si verificasse solo per "value_A0<400".
Lo scopo di questa richiesta è: visualizzare tre stati di umidità con un singolo led.
Ho provato a modificare il programma inserendo il blinking led con millis ma non funziona, potete aiutarmi?
Grazie in anticipo
FILE: hygrometer.05GIU17
TAG: LM393, FC28, HYGROMETER, SOIL, MOISTURE, LED, BLINK
PURPOSE: Soil moisture test program
PROBES: LM393+FC28
VERSION: 05GIU17
DISPLAY: NC
COMFORT: humid soil: 200 < value < 500
AUTHOR: Antonio Cannavale
Soil moisture sensor connected to Arduino as follow:
GND -> GND
VCC -> +5V
D0 -> D12
A0 -> A0
// Initializing variables:
unsigned long previousMillis=0; // Store the last time read was updated:
unsigned long previousMillisBlink=0;
const int intervalBlink=500;
const int interval=10000; // Set a delay time (milliseconds):
const int greenLED_A0=12; // Indicator green led connect at Digital PIN D12:
int ledState=LOW;
int soil_moisture_A0=0; // Read from Analog PIN A0:
int value_A0=0; // Store the value coming from the sensor A0:
float volts_A0=0; // Store the volt coming from the sensor A0:
// Set to true to print status messages to the serial:
boolean DEBUG=true;
// The setup function runs once when you press reset or power the board:
void setup() { // Start setup:
// We start the serial library to output our messages:
if (DEBUG) {
} // End if:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only:
} // End while:
pinMode(soil_moisture_A0,INPUT); // Set analog pin as an INPUT:
pinMode(greenLED_A0,OUTPUT); // Set digital pin as an OUTPUT:
Serial.println(F("\nSoil moisture sensor"));
Serial.println(F("--------------------"));
digitalWrite(greenLED_A0, LOW); // Switch off Green LED Indicator:
delay(500); // Delay to let system boot:
// Record the time once the setup has completed:
previousMillis = millis();
previousMillisBlink = millis();
} // End setup:
// The loop function runs over and over again forever:
void loop() { // Start loop:
// Check whether it has been long enough:
if (millis() - previousMillis >= interval) {
// Read Soil Moisture values:
value_A0=analogRead(soil_moisture_A0); // Read from analog pin:
volts_A0=(value_A0/1023.0)*5.0; // Conversion to volts:
// Check soil hymidity:
if(value_A0>400 & value_A0<500) {
digitalWrite(greenLED_A0,HIGH); // Swith on indicator led:
Serial.print(F("humid soil, "));
if(value_A0<399) {
Serial.print(F("wet soil, "));
if (millis() - previousMillisBlink >= intervalBlink) {
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
digitalWrite(greenLED_A0,ledState);
if(value_A0>501) {
digitalWrite(greenLED_A0,LOW); // Swith off indicator led:
Serial.print(F("dry soil, "));
// Send soil Moisture values to serial communication:
Serial.print(F("sensor A0: ")) & Serial.print(value_A0) & Serial.print(F(", ")) & Serial.print(volts_A0,2) & Serial.println(F("V"));
previousMillis = millis(); // Store the current time:
} // End if:
} // End loop:
fratt:
nella stessa riga vedo un errore anch'io...
se vuoi l'AND logico devi usare &&.
Ciao,
io intendevo "tutti i valori compresi tra 400 e 500".
comunque anche inserendo questa modifica il led non lampeggia in quel intervallo.
Avete altri suggerimenti?
antoniocnn:
Con (value_A0<399) testi i valori da 0 a 398
Con (value_A0>400 & value_A0<500) testi i valori da 401 a 499
Con (value_A0>501) testi i valori da 502 al massimo.
I valori 399, 400, 500, 501 vengono ignorati (nessuna condizione risulta vera).
In questo specifico caso usare & o && non cambia.
Quale intervallo? Il lampeggio è messo nella condizione da 0 a 398 ed è scritto giusto, anche se potrebbe essere molto più compatto. Impostando a mano value_A0 ad un valore inferiore a 399 il LED deve lampeggiare.
Claudio_FF:
Praticamente quando legge si accende e resta acceso e quando ri-legge si spegne e resta spento.
Ho suggerito di impostare a mano i valori di value_A0 per poter testare il regolare funzionamento di quegli if: - dando un valore inferiore a 399 il LED deve lampeggiare - dando un valore superiore a 501 deve stare spento - dando un valore tra 401 e 499 deve stare acceso. (questa è la logica che hai scritto) Se questi comportamenti sono corretti, allora il problema si sposta da un'altra parte, e la domanda da "perché non lampeggia" diventerebbe: "perché il valore letto di value_A0 è sbagliato?"
Vedo adesso che gli if sono all'interno di un if principale che li blocca per 10 secondi. Per questo non lampeggia.
Il lampeggio va messo nel loop principale fuori dalla struttura:
Quindi va usata un'altra variabile flag, impostata dentro la struttura, e letta all'esterno dal lampeggiatore:
All'interno degli if che testano gli intervalli, va impostato il valore di blinkON in modo che la funzione all'esterno della struttura (che viene eseguita in continuazione) lampeggi solo quando serve.
Claudio_FF:
Questo led non ne vuole sapere di lampeggiare.
Ecco il codice che attualmente utilizzo.
Qualcuno può ancora aiutarmi?
Grazie in anticipo
TAG: LM393, FC28, HYGROMETER, SOIL, MOISTURE, LED, BLINK, MILLIS
PROBES: LM393+FC28
VERSION: 05GIU17
DISPLAY: NC
GND -> GND
VCC -> +5V
D0 -> D12
A0 -> A0
unsigned long previousMillisBlink=0; // Store last time LED was updated:
// Variables constant:
// Variables will change:
int ledState=LOW; // ledState used to set the LED
boolean DEBUG=true;
if (DEBUG) {
} // End if:
while (!Serial) {
} // End while:
} // End setup:
if(value_A0>=400 & value_A0<=500) {
if(value_A0<400) {
blink(200); // Led will blink every 200ms
if(value_A0>501) {
// Store the current value:
} // End if:
} // End loop:
// Function Blinking indicator led:
void blink(int intervalBlink) {
// If the LED is off turn it on and vice-versa:
ledState = HIGH;
else {
ledState = LOW;
// Set the LED with the ledState of the variable:
digitalWrite(greenLED_A0, ledState);
} // End if:
} // End blink:
Ciao,
credo che neanche sta volta sono riuscito nel mio scopo.
Secondo voi ho fatto bene a smembrare il codice loop in singole funzioni?
Grazie
PROBES: LM393+FC28
VERSION: 05GIU17
DISPLAY: NC
GND -> GND
VCC -> +5V
D0 -> D12
A0 -> A0
boolean DEBUG=true;
if (DEBUG) {
} // End if:
while (!Serial) {
} // End while:
} // End setup:
read (10000); // Read value every 10s:
check (); // Check state soil humidity:
blink (200); // Blink led every 200ms.
} // End loop:
// Function read soil hymidity:
void read(int interval) {
//Serial.print(F("Time : ")) & Serial.print(millis()) & Serial.print(F(", "));
} // End read:
// Function check state soil himidity:
void check() {
if(value_A0>=400 && value_A0<=500) {
if(value_A0<400) {
if(value_A0>501) {
} // End check:
// Function blinking indicator led:
int blink(int intervalBlink) {
ledState = HIGH;
else {
ledState = LOW;
} // End blink:
[code]
int soil_moisture_A0 = 0; // Read from Analog PIN A0:
pinMode(soil_moisture_A0, INPUT); // Set analog pin as an INPUT:
stai attribuendo a soil_moisture_A0 il valore 0 (non A0) e poi usi questa variabile per dichiarare il pin 0 come input...che è un digitale.
ricorda inoltre che per in pin analogici non serve dichiarare il pinmode() quando sono usati come input.
secondo me dovresti dichiarare soil_moisture_A0 in questo modo:
#define soil_moisture_A0 A0
non dichiarare il pinmode()...in questo modo ai tuoi analogRead(soil_moisture_A0) è come se scrivessi analogRead(A0).
questo è quello che ho visto...prova e facci sapere.
Ho modificato lo sketch come indicato da ORSO2001.
Come potete vedere ho inserito // accanto alle linee di codice per tracciare i cambiamenti.
Il led lampeggia continuamente.
PROBES: LM393+FC28
VERSION: 05GIU17
DISPLAY: NC
GND -> GND
VCC -> +5V
D0 -> D12
A0 -> A0
//int soil_moisture_A0=0;
#define soil_moisture_A0 A0 // Read from Analog PIN A0:
boolean DEBUG=true;
if (DEBUG) {
} // End if:
while (!Serial) {
} // End while:
//pinMode(soil_moisture_A0,INPUT); // Set analog pin as an INPUT:
} // End setup:
} // End loop:
} // End read:
void check() {
if(value_A0<400) {
if(value_A0>501) {
} // End check:
ledState = HIGH;
else {
ledState = LOW;
} // End blink:
ciao...scusa mi sono un attimo perso...il fatto che lampeggi continuamente è quello che vuoi?
nel loop() hai inserito la funzione blink(200); dove 200 è l'intervallo per il confronto.
la funzione blink() dice:
ledState = HIGH;
else {
ledState = LOW;
} // End blink:
tralasciando che la funzione la potevi dichiarare come void in quanto non torna alcunché... in pratica ogni 200 ms il LED cambia di stato indipendentemente da altro...altro consiglio è quello di chiamare le tue funzioni con "nome" diverso da quello dello namespace standard...come vedi blink e read hanno colore diverso (arancio) da check (nero)...questo perchè sia blink che read sono presenti nella lista Keywords in quanto presenti in librerie in uso...
