Ciao a tutti,
Ho bisogno di sapere qual è il risultato maggiore tra 18 formule diverse per poi eseguire un calcolo...
La funzione max accetta solo due valori, quindi niente.
Ho provato con una serie di if, ma dopo il quinto non da più feedback in seriale.
Come potrei fare?
Grazie!
float Thrust0; float Thrust1; float Thrust2; float Thrust3; float Thrust4; float Thrust5; float Thrust6; float Thrust7; float Thrust8; float Thrust9; float Thrust10; float Thrust11; float Thrust12; float Thrust13; float Thrust14; float Thrust15; float Thrust16; float Thrust17;
float maxThrust = 0;
Thrust0 = ((0.5*air*(Cl[0])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[0])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust1 = ((0.5*air*(Cl[1])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[1])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust2 = ((0.5*air*(Cl[2])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[2])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust3 = ((0.5*air*(Cl[3])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[3])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust4 = ((0.5*air*(Cl[4])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[4])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust5 = ((0.5*air*(Cl[5])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[5])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust6 = ((0.5*air*(Cl[6])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[6])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust7 = ((0.5*air*(Cl[7])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[7])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust8 = ((0.5*air*(Cl[8])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[8])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust9 = ((0.5*air*(Cl[9])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[9])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust10 = ((0.5*air*(Cl[10])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[10])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust11 = ((0.5*air*(Cl[11])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[11])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust12 = ((0.5*air*(Cl[12])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[12])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust13 = ((0.5*air*(Cl[13])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[13])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust14 = ((0.5*air*(Cl[14])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[14])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust15 = ((0.5*air*(Cl[15])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[15])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust16 = ((0.5*air*(Cl[16])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[16])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust17 = ((0.5*air*(Cl[17])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[17])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
maxThrust = Thrust0;
if(maxThrust < Thrust1) {
maxThrust = Thrust1;
//Serial.println(maxThrust, 5);
//Serial.println(Thrust1);
if(maxThrust < Thrust2) {
maxThrust = Thrust2;
//Serial.println(Thrust2);
if(maxThrust < Thrust3) {
maxThrust = Thrust3;
//Serial.println(Thrust3);
if(maxThrust < Thrust4) {
maxThrust = Thrust4;
//Serial.println(Thrust4);
if(maxThrust < Thrust5) {
maxThrust = Thrust5;
Serial.println(Thrust5);
DEVI usare un vettore/array, ovvero un contenitore con nome unico e con un indice accedi ai vari elementi.
Questo permette di lavorare con cicli for su tutti gli elementi.
Studiati su un sito o libro i vettori/array del linguaggio C
P.S. i tuoi Cl e Cs già sono degli array
E dopo...
float Thrust[18];
Thrust[0] = ((0.5*air*(Cl[0])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[0])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[1] = ((0.5*air*(Cl[1])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[1])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[2] = ((0.5*air*(Cl[2])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[2])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[3] = ((0.5*air*(Cl[3])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[3])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[4] = ((0.5*air*(Cl[4])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[4])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[5] = ((0.5*air*(Cl[5])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[5])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[6] = ((0.5*air*(Cl[6])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[6])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[7] = ((0.5*air*(Cl[7])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[7])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[8] = ((0.5*air*(Cl[8])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[8])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[9] = ((0.5*air*(Cl[9])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[9])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[10] = ((0.5*air*(Cl[10])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[10])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[11] = ((0.5*air*(Cl[11])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[11])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[12] = ((0.5*air*(Cl[12])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[12])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[13] = ((0.5*air*(Cl[13])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[13])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[14] = ((0.5*air*(Cl[14])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[14])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[15] = ((0.5*air*(Cl[15])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[15])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[16] = ((0.5*air*(Cl[16])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[16])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Thrust[17] = ((0.5*air*(Cl[17])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[17])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
for(float BestThrust = 0; BestThrust < 18; BestTrust++) {
gpb01
October 8, 2019, 3:21pm
4
Imposti una variabile, ad esempio 'massimo' di tipo float a 0.0, dopo di che nel ciclo for la compari con ogni elemento; se essa è maggiore o uguale, non fai nulla, se è minore assegni quell'elemento alla variabile.
Alla fine del for, la variabile che abbiamo chiamato 'massimo' conterrà il valore massimo trovato.
Guglielmo
Così?...
for(int i = 0; i < 18; i++) {
if(massimo < Thrust[i]) {
massimo = Thrust[i];
BestThrust = massimo;
Serial.print(BestThrust, 5);
gpb01
October 8, 2019, 3:58pm
6
Lo hai provato ? ... è il miglior modo per sapere se hai fatto bene
Guglielmo
P.S.: Perché per stampare 'massimo' lo assegni ad un'altra variabile? Allora potevi usare direttmente quella allo stesso modo ... ogni 'float' che dichiari si mangia ben 4 bytes della preziosa SRAM, quindi ... impara ad evitare gli sprechi ...
I valori vengono calcolati sulla base di una funzione che è sempre la stessa e che dipende da un indice:
float myDummyFunct(int index)
return ((0.5*air*(Cl[index])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[index])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
Quindi puoi anche evitare di fare l'array:
float maxValue = myDummyFunct(0);
for(int i = 1; i < 18; i++)
float tmp = myDummyFunct(i);
maxVaue = tmp > maxValue ? tmp : maxValue;
Dovrebbe essere giusto così controllerò i calcoli.
Sisi elimino "massimo"... era solo per una prova veloce.
Grazie a tutti!
C'è un altro problema...
Quando AWA aumenta, il risultato più alto tra i calcoli viene mostrato correttamente.
Quando diminuisce invece, il risultato non cambia. Rimane l'ultimo trovato... non si aggiorna...
Come mai?
gpb01
October 9, 2019, 11:12am
10
Scusa, ma se cerchi il massimo, sempre il massimo ti da.
Se la serie di valori cambia, prima devi di nuovo azzerare la variabile che usi per salvare il massimo, altrimenti sempre il vecchio massimo dentro c'è (vado a naso, visto che non hai messo il codice che stai usando ).
Guglielmo
Dovrei azzerare le variabili fuori da questo void, perchè l'AngleOfAttack poi mi serve, e non voglio che si azzeri prima di averlo usato, giusto?
void calcTHR() {
if(time>calcola_THR_time + 3000) {
if(BestThrust < Thrust[i]) {
BestThrust = Thrust[i];
if(TWA180 > 0 && TWA180 < 180) {
if(BestThrust == Thrust[0]) {
AngleOfAttack = MasterAngle[0];
else if(BestThrust == Thrust[1]) {
AngleOfAttack = MasterAngle[1];
else if(BestThrust == Thrust[2]) {
AngleOfAttack = MasterAngle[2];
else if(BestThrust == Thrust[3]) {
AngleOfAttack = MasterAngle[3];
else if(BestThrust == Thrust[4]) {
AngleOfAttack = MasterAngle[4];
else if(BestThrust == Thrust[5]) {
AngleOfAttack = MasterAngle[5];
else if(BestThrust == Thrust[6]) {
AngleOfAttack = MasterAngle[6];
else if(BestThrust == Thrust[7]) {
AngleOfAttack = MasterAngle[7];
else if(BestThrust == Thrust[8]) {
AngleOfAttack = MasterAngle[8];
else if(BestThrust == Thrust[9]) {
AngleOfAttack = MasterAngle[9];
else if(BestThrust == Thrust[10]) {
AngleOfAttack = MasterAngle[10];
else if(BestThrust == Thrust[11]) {
AngleOfAttack = MasterAngle[11];
else if(BestThrust == Thrust[12]) {
AngleOfAttack = MasterAngle[12];
else if(BestThrust == Thrust[13]) {
AngleOfAttack = MasterAngle[13];
else if(BestThrust == Thrust[14]) {
AngleOfAttack = MasterAngle[14];
else if(BestThrust == Thrust[15]) {
AngleOfAttack = MasterAngle[15];
else if(BestThrust == Thrust[16]) {
AngleOfAttack = MasterAngle[16];
else if(BestThrust == Thrust[17]) {
AngleOfAttack = MasterAngle[17];
} else if(TWA360 > 180 && TWA360 < 360) {
AngleOfAttack = 360-MasterAngle[17];
AngleOfAttack = 360-MasterAngle[16];
AngleOfAttack = 360-MasterAngle[15];
AngleOfAttack = 360-MasterAngle[14];
AngleOfAttack = 360-MasterAngle[13];
AngleOfAttack = 360-MasterAngle[12];
AngleOfAttack = 360-MasterAngle[11];
AngleOfAttack = 360-MasterAngle[10];
AngleOfAttack = 360-MasterAngle[9];
AngleOfAttack = 360-MasterAngle[8];
AngleOfAttack = 360-MasterAngle[7];
AngleOfAttack = 360-MasterAngle[6];
AngleOfAttack = 360-MasterAngle[5];
AngleOfAttack = 360-MasterAngle[4];
AngleOfAttack = 360-MasterAngle[3];
AngleOfAttack = 360-MasterAngle[2];
AngleOfAttack = 360-MasterAngle[1];
AngleOfAttack = 360-MasterAngle[0];
//Serial.println(BestThrust, 5);
//Serial.println(AngleOfAttack);
calcola_THR_time=millis();
time=millis();
leggiAWS();
leggiAWA();
scriviSuDisplay();
calcTW();
//calcTHR();
scriviSuMicroSD();
if(AWS < 9) {
digitalWrite(green_led, HIGH);
digitalWrite(red_led, LOW);
digitalWrite(yellow_led, LOW);
calcTHR();
myStepper.run();
angle = AngleOfAttack*gear_ratio;
myStepper.moveTo(-angle/stepPerAngle);
calcTHR();
myStepper.run();
gpb01
October 9, 2019, 1:20pm
12
Devi azzerare quella che ogni volta usi per calcolare il massimo , mi sembra BestThrust ... :
Ti suggerisco anche di imparare ad usare bene il ciclo FOR ... il tuo programma si ridurrebbe di parecchio
Guglielmo
Boh, ti diciamo di usare i vettori perchè così puoi usare i cicli for e non lo fai.
etc.
diventa
for(int i=0;i<=17;i++)
{ Thrust[i] = ((0.5*air*(Cl[i])*AWS*AWS*Atot)*sin(radians(AWA))-(0.5*air*(Cd[i])*AWS*AWS*Atot)*cos(radians(AWA)))/1000;
(scusate risposta doppia..)
Oltretutto a te non serve il valore massimo, ma l'indice corrispondente..
int maxIndex = -1;
maxIndex = i;
In modo che poi l'If kilometrico diventa semplicemente:
AngleOfAttack = MasterAngle[maxIndex];
AngleOfAttack = 360-MasterAngle[17 - maxIndex];
Okay grazie.
Non mi è chiaro questo...
L'ultimo indice MasterAngle meno l'indice della formula che da il massimo risultato come fa ad associare l'indice della formula all'indice corrispondente del MasterAngle?
Da 0 a 180 gradi funziona (con BestThrust = 0 prima di int maxIndex), da 180 a 360 però no..
Mattia_L:
Okay grazie.
Nel tuo codice originario facevi così:
Cioè se il bestThrust era all'indice 0, usavi l'elemento masterAngle all'indice 17, all'1 il 16 e così via..
In pratica associ ad un indice il suo complementare e per trovare il complementare di un valore basta sottrarlo al valore massimo.
Ricavando l'indice di MasterAngle in base a quello di thrust riesci a metterli in relazione senza utilizzare 17 if differenti.
ciao
Okay grazie ho capito.
Adesso però funziona solo se l'AWA è minore di 180. Quando è maggiore, l'AngleOfAttack da sempre 360...
if(AWA < 180) {
else if(AWA > 180) {
AngleOfAttack = 360-MasterAngle[17-maxIndex];
gpb01
October 10, 2019, 1:23pm
18
>Mattia_L : ti rammento che da REGOLAMENTO NON è permesso fare "up " (sollecitare risposte ), prima di 48 ore dall'ultimo post. Grazie.
Guglielmo
Mattia_L:
Posta il contenuto dell'array thrust e di quello maxAngle in una delle esecuzioni errate.
Thrust
0.00
-0.11
-0.22
-0.32
-0.42
-0.51
-0.59
-0.60
-0.55
-0.49
-0.46
-0.47
-0.49
-0.45
-0.36
-0.24
-0.10
0.05
BestThrust 0.05
maxIndex 17
AngleOfAttack 360.00
