RN-42 Bluetooth communication stopped
Hello Everybody,
I'm using a RN-42 module in order to send two data sensors (pressure (analog data) and mass flow (i2c data)) from arduino uno to my PC, visualizing them on serial monitor.
I use also a slide switch in order to keep the bluetooth and the sensor off and on as I want.
The problem comes when I switch on the circuit, because in order to visualize the data from bluetooth COM port I have to visualize them first from serial Arduino COM port.
After have opened the serial monitor of arduino COM, I can visualize the data also from the serial monitor of bluetooth COM.
Everytime i switch off and on the circuit, I have to do this.
Which could be the problem?
It could be a code problem or a bluetooth one?
I post the code below, hoping to be more clear:
#include <Wire.h>
#define address 0x40
#define offset 32768
#define scale_factor 120 // from sensor datasheet
unsigned int d;
byte a,b,c;
int a1,b1,c1;
float flow;
Wire.begin();
Wire.beginTransmission(address);
Wire.write(16);
Wire.write(0);
Wire.endTransmission();
Wire.requestFrom(address,3); // to read flow sensor byte
a=Wire.read();
b=Wire.read();
c=Wire.read();
a1=int(a);
b1=int(b);
d=(a1*256)+b1;
Serial.print("\t");
flow=((d-offset)/float(scale_factor));
Serial.print(flow);
Serial.print("\t");
int sensorValue=analogRead(A0);
float pressure=(sensorValue*0.3965)-40.3512-160; //from pressure sensor datasheet
Serial.print("|");
Serial.print("\t");
Serial.println(pressure);
delay(30);
kaisy:
I'm using a RN-42 module in order to send two data sensors, visualizing them on serial monitor.
You seem to imply that you can send data direct to the serial monitor. If that is the case, and even though I would question such a short delay, there is clearly nothing wrong with the code. You don't use the serial monitor with bluetooth. Use a proper terminal programme like RealTerm. It also enables you to record the data which, at that speed, might also be a good idea.
