RN42, connection two module problems
Hello
I have two module RN42, firmware 6.15. No problem connect to Pc, and Nokia ld3w, but I can't connected two module together. I tried lots of options, like SA,0, SA,4, DCE, DTE
Configuration master:
Settings
BTA=000666603771
BTName=FireFly-3771
Baudrt(SW4)=9600
Mode =Mstr
Authen=4
PinCod=0000
Bonded=0
Rem=000666605726
OTHER Settings
Profile= SPP
CfgChar= $
SniffEna=0
LowPower=0
TX Power=0
IOPorts= 0
IOValues=0
Sleeptmr=0
DebugMod=0
RoleSwch=0
Configuration of slave:
Settings
BTA=000666605726
BTName=FireFly-5726
Baudrt(SW4)=9600
Mode =Slav
Authen=4
PinCod=0000
Bonded=0
Rem=NONE SET
OTHER Settings
Profile= SPP
CfgChar= $
SniffEna=0
LowPower=0
TX Power=0
IOPorts= 0
IOValues=0
Sleeptmr=0
DebugMod=0
RoleSwch=0
common configuration:
ADVANCED Settings
SrvName= SPP
SrvClass=0000
DevClass=1F00
InqWindw=0100
PagWindw=0100
CfgTimer=255
StatuStr=%
HidFlags=200
DTRtimer=8
KeySwapr=0
When I try connect C:
TRYING
%NEW_PAIRING
CONNECT failed
sorry for my bad english.
RN Technology Used : Bluetooth
RN FirmWare Used : 6.15 RN Subject : Connecting two module
RN Hardware used : PC
Have you figured this out? I am having the same problem. I successfully connected the RN-42 modules to my iPhone, but cannot get them to connect to each other.
up up!
Reviving this topic because I have some doubts about connecting to RN42 modules.
And my first question is:
Using the authentication system for pairing, the first time the master module tries to pair with the slave module they should exchange pin codes. Where are these pin codes saved or do I have to program the slave module to send the pin code at some point?
