Hi! I’m searching for a way to use RN42 as a bluetooth keyboard and act like keyboard.h do. Simply putting
keyboard.press(); or keyboard.releaseAll();
I stumbled upon this code while searching how to use RN42 as a keyboard by silverball
CODE BY SILVERBALL
RN42_HIDRaw_Arduino.cpp - Roving Netowrks RN42 Bluetooth HID raw library
Developed by Chris Leitner - 2012
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
RN42 HID raw report format:
|start(1 byte)|length(1 byte)|descriptor(1 byte)|data(length - 1 [for the descriptor])
Keyboard:
|0xFD|9|1|modifier|0x00|code 1|code 2|code 3|code 4|code 5|code 6
Keyboard modifier bits (sent as one byte)
bit 7 |bit 6 |bit 5 |bit 4 |bit 3 |bit 2 |bit 1 |bit 0
rt GUI |rt alt |rt shift |rt ctrl|lt GUI |lt alt |lt shift |lt ctrl
You must initialize the Serial library in your code before you call any of these functions.
The default speed for the RN42 is 115200 - add this in the setup function Serial.begin(115200);
#include <stdlib.h>
#include <string.h>
#include <inttypes.h>
#include "RN42_HIDRaw_Arduino.h"
RN42_HIDRaw_Arduino::RN42_HIDRaw_Arduino(){
//Sends a raw report for a keyboard HID
void RN42_HIDRaw_Arduino::SendKeyboardRaw(char raw_data[], uint8_t mod_bit){
//write the RN42 Keyboard raw header
Serial.write((uint8_t)0xFD); //start byte indicator for RN42
Serial.write((uint8_t)0x09); //length of the raw report (how many bytes)
Serial.write((uint8_t)0x01); //descritptor byte see the RN42 HID manual for details 0x01 is keyboard
Serial.write((uint8_t)mod_bit); //modifier bit (indicates shift, control, and other keys (see comments above)
Serial.write((uint8_t)0x00); //unused always send 0x00
//write the key press data
//each of these should be an ASCII keycode indicating a keypressed
//example 0x04 is an 'a' see the RN42 HID manual for a list of codes
Serial.write((uint8_t)raw_data[0]);
Serial.write((uint8_t)raw_data[1]);
Serial.write((uint8_t)raw_data[2]);
Serial.write((uint8_t)raw_data[3]);
Serial.write((uint8_t)raw_data[4]);
Serial.write((uint8_t)raw_data[5]);
//This function just send a raw report with no keys or modifiers pressed
void RN42_HIDRaw_Arduino::SendKeyboardRawBlank(void){
//Sends a raw report for a gamepad
void RN42_HIDRaw_Arduino::SendGamepadRaw(char x_left, char y_left, char z_pos, char rot_pos, uint8_t buttons1, uint8_t buttons2)
//write the header part for RN42
Serial.write((uint8_t)0x06); //length of the descriptor
//gampad positions and buttons
//on a gamepad there typically is two analog joysticks one is typically used to
//indicate x/y position and one is for z/rotation.
Serial.write((uint8_t)x_left); //value between -127 to 127 indicating the x postition
Serial.write((uint8_t)y_left); //value between -127 to 127 indicating the y postition
Serial.write((uint8_t)z_pos); //value between -127 to 127 indicating the z postition
Serial.write((uint8_t)rot_pos); //value between -127 to 127 indicating the rotation postition
//one bit for each button pressed there can be a total of 16 buttons one byte in each
//set the bit to show a button pressed and clear the bit to indicate not pressed
Serial.write((uint8_t)buttons1);
Serial.write((uint8_t)buttons2);
void RN42_HIDRaw_Arduino::SendMouseRaw(uint8_t buttons, uint8_t x_stop, uint8_t y_stop, uint8_t wheel){
Serial.write((uint8_t)0x05);
Serial.write((uint8_t)0x02);
Serial.write((uint8_t)buttons);
Serial.write((uint8_t)x_stop);
Serial.write((uint8_t)y_stop);
Serial.write((uint8_t)wheel);
but i dont have any idea how to use it. So, can i use it as keyboard.h do ? how can i use it? to substitute to this code
CODE I WANT TO USE
This is a library for the APDS9960 digital proximity, ambient light, RGB, and gesture sensor
This sketch puts the sensor in gesture mode and decodes gestures.
To use this, first put your hand close to the sensor to enable gesture mode.
Then move your hand about 6" from the sensor in the up -> down, down -> up,
left -> right, or right -> left direction.
Designed specifically to work with the Adafruit APDS9960 breakout
----> http://www.adafruit.com/products/3595
These sensors use I2C to communicate. The device's I2C address is 0x39
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Dean Miller for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include "Adafruit_APDS9960.h"
#include <Keyboard.h>
Adafruit_APDS9960 apds;
#define INT_PIN 4
// the setup function runs once when you press reset or power the board
if(!apds.begin()){
Serial.println("failed to initialize device! Please check your wiring.");
else Serial.println("Device initialized!");
//gesture mode will be entered once proximity mode senses something close
apds.enableProximity(true);
apds.enableGesture(true);
Keyboard.begin();
// the loop function runs over and over again forever
// read a gesture from the device
// see list of all keys here: https://www.arduino.cc/en/Reference/KeyboardModifiers
uint8_t gesture = apds.readGesture();
if(gesture == APDS9960_DOWN){
Keyboard.press(KEY_ESC);
delay(100);
Keyboard.releaseAll();
Serial.println("DOWN");
if(gesture == APDS9960_UP){
Keyboard.press(KEY_F11);
delay(100);
Serial.println("UP");
if(gesture == APDS9960_LEFT){
Keyboard.press(KEY_LEFT_ARROW);
delay(100);
Serial.println("LEFT");
if(gesture == APDS9960_RIGHT){
Keyboard.press(KEY_RIGHT_ARROW);
delay(100);
Serial.println("RIGHT");
