Roast me (setup problems)
Hello everyone,
I've been dabbling in some simple electronics for a small project of mine and have been running into an issue. I am probably doing something wrong hardware-wise, so I would appreciate some feedback from ppl more electronics-savvy than I am (really not my core business lol). I've attached a small schematic of the setup (it is simplified, there are actually 3 probes and 3 DC motors, + a SD card with a shield but it remains off the main board).
The idea is the following: everything remains unpowered until the main loop triggers the following sequence:
1. probe transistor is switched "on" by a pin_high command.
2. there is an analog read from the probe output (which is 0-5V ofc).
3. value is saved and the transistor is opened by a pin_low signal.
4. DC motor is activated with a pin_high during a time determined by the collected probe value.
My problem is than one of those probe really CANNOT keep it's calibration, the measure is drifting constantly, so i've been measuring voltages here&there to find problems and I did, so to break down the thing into actual points:
1. If i take the voltage around the DC motors while the transistor is "off", i get the expected 0 volt, the 12V being between the collector and emitter, all good on that side.
2. This is where it hurts, if I take the voltage on the probes (which are supposed to be unpowered), i get a whopping 16V, the remainder 8V being at V_CE, whilst the circuit is supposed to be opened at that location. This is weird because the transistor is supposed to be rated for this voltage (2N2222A). There is clearly something that i'm missing here.
I'm guessing there is some amateurish mistakes in the setup which compromise the integrity of my probe's module (no reason to think it's faulty due to it giving correct value right after calibration).
Really appreciate the time for reading me, thanks a lot !
You need a base resistor. In the upper drawing, the inductive kick diode is backwards.
Please post a link to the motor. Note that the 2N2222 can handle at most 800 mA. Most small motors draw much more when starting.
What is the probe? Post a link.
With diode reversed, as on your schematic, you're making short circuit when transistor is on... Also, always use at least 1K base resistor when using them for switching.
Hi & thanks for the feedback.
@jremington what kind of value would that resistor be ? Is the lack of it harming the arduino or the probe ?
The motor is 5W so nominally it's within range; i'll try to find its datasheet. Apparently I cannot post attachments so I cannot link the probe datasheet, what key information were you looking for ?
@both the diode is reversed on the schematic, my mistake, on the board it is correctly plugged.
As I said, there is nothing seemingly wrong with the motor part, only the 24V line that shows weird voltages when the circuit is supposed to be opened.
Cheers !
Almost certainly not. You need to know the stall current, not the "nominal" operating power. :face_with_raised_eyebrow:
Better rustle up that datasheet! :grin:
Is is online anywhere? You should be able to post a web link (URL).
My worry is the output voltage levels. Yeah, you said 0-5V "ofc" but I would be more comfortable seeing that on a spec sheet.
Also, controlling the probe power supply (if I am interpreting the function correctly) with a low side driver means, when it's off, the output voltage could be 24V.
That would fry the transistor.
Better calculate required base current for the load you're switching.
Leo..
They are probably allready fried.. Sorry I meant at least 10K.
Before trying again (with correct schematic) install new transistors.
BJT transistors for switching must be fully saturated (lots of base current), otherwise they get hot and pop their tops. That makes most of them unsuitable for current over ~500mA with the limited base current an Arduino pin can provide.
I would use a 220ohm (150-330) resistor for up to a few hundred mA collector current.
Above that you could use a darlington transistor (TIP120) if... you can stand the 1-2volt CE loss.
If not, use a logic level mosfet.
Leo..
They are pretty cheap.
Possibly because they are essentially obsolete, replaced by FETs. :roll_eyes:
That would be even worse. Please take some time to learn about bipolar transistor circuit design, before posting about it.
Im in electronics for 20 years and still havent learned anything, it`s great there are such experts round here... :wink:
@noobmastha: Why do you bother to post misinformation?
What misinformation?? :smiley: Mate, you have great personality for reality shows ...
overAndOut();
Welcome to my ignore list!
Just as well, it seems! :rofl:
Ok I am realizing I'm super behind in electronics so thanks in advance for putting up with me ^^.
Concerning the motor: I could not find the exact model's datasheet but it's a variation of this one http://descargas.cetronic.es/RS-385SH.pdf although probably less powerfull; nevertheless, the stall current (which I forgot existed) is indeed way out of bound. My model has less power/current, so would a good idea be to put a resistor in series with it to make it run at lower power and reduce the current(s) ? One thing I'm not understanding is why nothing seems broken in that particular circuit, the transistor does its job just fine even if it is supposed to be overstrained...
Concerning the base resistor, I've read up a bit so i'll go on a hypothesis here: I need to find my probe's module resistance, which is basically R_collector; I then get the saturation current with I_C = 24V / R_collector, and I then linearly interpolate the needed V_BE from the datasheet excerpt below to get the value of the base resistor. This probably won't work but to what degree is this line of reasonning correct ?
Again thanks a lot, and please don't fight <3
Yes, if you want to drastically impair its performance; starting and running torque etc. :thinking:
As for the base resistors, just get a proper logic-level FET. Don't use 1980s BJTs.
Well, motor performance is not really an issue, and if this saves my switches from a risk of frying...
BJTs is all I have atm so why not use them if they can work ? That also makes for a good exercise... Nevertheless, do you have a specific model in mind that would be appropriate ?
Thanks :slight_smile:
Up :hugs:
