Robot algorythim to clean 2x2m balcony!
I have 2x2m balcony, there is 3 chairs in it.
I want to build a robot to clean it everyday.
I saw a lot of projects for arduino cleaning robot but it's a complete random moving.
Because it's random, it could pass the area a couple of times and not hitting other areas.
That's require big battery because it will run for hours until everything is clean.
I have cleaning robot xiaomi, but there is stairs, so it can't go there.
I tried to make the xiaomi clean it and finished everything in 2 mins.
because it has mapping future.
I want to build something simple without adding expense lidar sensors. just a couple of ultrasonic and infrared sensors.
With two motors, not sure what motor to use yet.
Any suggestions for the algorithm?
Can you make a map for your robot to follow (and to avoid the stairs)?
I can, but the chairs can move slightly 5-10cm.
I will remove the table tho
Here is a pic:
There is a door frame, so the robot will not fall from the stairs
I found this list of things that might help you...
That's how lawn moving robots work. Time makes them pass all spots.
If you create a line-following robot, you could lay tape and have the robot follow the line (about 20cm wide).
