Robot Avoidance Help
Hello so basically i started with arduino bought a cheap chinese kit online, and well put it together. After putting together a script, I uploaded it to my creation. And now my robot spins around in circles endlessly but avoid anything i put in front of it. So my question is was the code shoddy as hell or perhaps its a wiring problem.
Robot Avoiding Vehicle .ino (5.26 KB)
Here for simplicity of viewing is the OP's code:
#include <Servo.h>          //Servo motor library. This is standard library
#include <NewPing.h>        //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 5; // left motor foward
const int LeftMotorBackward = 4;// left motor back
const int RightMotorForward = 3; // right motor foward
const int RightMotorBackward = 2; // right motor backward
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 100 // in cm
boolean goesForward = false;
int distance = 50;    // changed it to 50 since...well.... my apartment is small
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
  pinMode(RightMotorForward, OUTPUT); // pinmode selecs the pin, then we write watever is the distance
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  servo_motor.attach(11); //our servo pin position on the arduino board
  servo_motor.write(90);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
  if (distance <= 20) { // if distance is less than 20
    moveStop();         // we stop
    delay(300);         //wait
    moveBackward();     // go backwards
    delay(400);         // wait
    moveStop();         // stop
    delay(300);         //wait
    distanceRight = lookRight(); // look to the right and record distance
    delay(300);                  // wait
    distanceLeft = lookLeft();   // look to the left then record distance
    delay(300);                  // wait
    if (distance >= distanceLeft) {  // if distance (50) is greater than the one on left we turn right then stop
      turnRight();
      moveStop();
    else {
      turnLeft();                      // else we move left
      moveStop();
  else {
    moveForward();                      // if neither we  move foward
  distance = readPing();              // then we ping and that becomes the new distance
// =================================================end of main============================================================================================================
int lookRight() {              // to look left
  servo_motor.write(10);     // servo_motor.write(10), where 10 equals a positon (position 10-90-170 or right middle left)
  delay(500);               // wait
  int distance = readPing();  // set the distance to whatever the new ping is
  delay(100);                   // wait
  servo_motor.write(90);        // then set motor to default location which is 10
  return distance;              // return distance
  delay(100);                   // wait
int lookLeft() {                 // to look right
  servo_motor.write(170);           // set it to positon 170 or left
  delay(500);                        // wait
  int distance = readPing();           // set ping as new distance
  delay(100);                          // wait
  servo_motor.write(90);               //set to middle
  delay(100);                            //wait
int readPing() {                   // read ping
  delay(70);                        // wait
  int cm = sonar.ping_cm();          // set distance of ping in cm
  if (cm == 0) {
    cm = 250;
  return cm;
//=========================================Movement===========================================================================================================
// low= nothing, high equals move
void moveStop() {
  digitalWrite(RightMotorForward, LOW); // we write for the robot to stop therefore all are low
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward() {
  if (!goesForward) {
    goesForward = true;
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(RightMotorForward, HIGH);
void moveBackward() {
  digitalWrite(LeftMotorBackward, HIGH);
  digitalWrite(RightMotorBackward, HIGH);
void turnRight() {
void turnLeft() {
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
The only information we have about your robot is that it is capable of spinning round in circles (not even if it's turning left or right). A little more information might be useful like what motors / motor driver, how it's powered and wired.
But I'd say your best bet is probably to put some Serial.prints in strategic positions and connect the USB cable to see in serial monitor where the code gets to, because it probably isn't where you think. Hold the robot in the air so it doesn't spin round or run away.
Steve
