My robot car won’t respond to my command. The code below worked before however, this time there is no response. I’ve tried experimenting with the code in the first while loop. I’ve tried different code from other projects similar to this. I’ve played with the schematics however, nothing seems to work.
This is my code:
#include <SoftwareSerial.h> // TX RX software library for bluetooth
#include <Servo.h> // servo library
Servo myservo1, myservo2, myservo3; // servo name
int bluetoothTx = 10; // bluetooth tx to 10 pin
int bluetoothRx = 11; // bluetooth rx to 11 pin
int motorOne = 4;
int motorOne2 = 5;
int motorTwo = 6;
int motorTwo2 = 7;
int enA = 3;
int enB = 2;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
//initial motors pin
char command;
char Value;
myservo1.attach(2); // attach servo signal wire to pin 9
myservo2.attach(8);
myservo3.attach(12);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(9600);
while (bluetooth.available() > 2) {
Value = bluetooth.read();
Serial.println(Value);
if ( Value == 'F') {
// Robo Pet Run Forward
digitalWrite(enA, 255);
digitalWrite(enB, 255);
digitalWrite(motorOne, HIGH);
digitalWrite(motorOne2, LOW);
digitalWrite(motorTwo, HIGH);
digitalWrite(motorTwo2, LOW);
} else if (Value == 'B') {
//Robo Pet Run Backward
digitalWrite(motorOne, LOW);
digitalWrite(motorOne2, HIGH);
digitalWrite(motorTwo, LOW);
digitalWrite(motorTwo2, HIGH);
} else if (Value == 'L') {
//Robo Pet Turn Left
} else if (Value == 'R') {
//Robo Pet Turn Right
} else if (Value == 'S') {
//Robo Pet Stop
//Read from bluetooth and write to usb serial
if(bluetooth.available()>= 2 )
unsigned int servopos = bluetooth.read();
unsigned int servopos1 = bluetooth.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println(realservo);
if (realservo >= 1000 && realservo <1180) {
int servo1 = realservo;
servo1 = map(servo1, 1000, 1180, 0, 180);
myservo1.write(servo1);
Serial.println("Servo 1 ON");
delay(10);
if (realservo >= 2000 && realservo <2180) {
int servo2 = realservo;
servo2 = map(servo2, 2000, 2180, 0, 180);
myservo2.write(servo2);
Serial.println("Servo 2 ON");
delay(10);
if (realservo >= 3000 && realservo <3180) {
int servo3 = realservo;
servo3 = map(servo3, 3000, 3180, 0, 180);
myservo3.write(servo3);
Serial.println("Servo 3 ON");
delay(10);
I’m using this app:
And here are the schematics:
