Hi
I was trying to build arduino robot car. I have small problem wich I cant solve. Here is a list of components :
1- Arduino board with sensor sheild v5.0.
2- Two 18650 Batteries.
3- Keyes l298 rev02 for motors driving.
4- Ultrasonic Sensor.
5- Four buttons in the edges of the robot to prevent it from stuck if hitting walls.
The right two tires are connected together and the left two tires are connected together.
I tried to run the l298 alone in separate project and it works very well. It move forward, backward, left and right with no problem.
But when I tried to program the robot with the components above the IN1 of l298 keep HIGH even after many attempts to turn it LOW. The problem is only in IN1.
I will put the sketch wich I am doing it.
/*-----------UltraSonic Sensor-----------*/
#define trigPin1 7
#define echoPin1 8
long duration, distance, FrontSensor;
/*-----------Motors-----------*/
int in1 = 1;
int in2 = 2;
const int ena = 5;
int in3 = 3;
int in4 = 4;
const int enb = 6;
/*-----------Direction-----------*/
int dir;
/*-----------Buttons-----------*/
const int buttonPin1 = 9;
int buttonState1 = 0;
const int buttonPin2 = 10;
int buttonState2 = 0;
const int buttonPin3 = 11;
int buttonState3 = 0;
const int buttonPin4 = 12;
int buttonState4 = 0;
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(ena, OUTPUT);
pinMode(enb, OUTPUT);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
randomSeed(2);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
buttonState1 = digitalRead(buttonPin1);
Serial.print(buttonState1);
Serial.write(" , ");
buttonState2 = digitalRead(buttonPin2);
Serial.print(buttonState2);
buttonState3 = digitalRead(buttonPin3);
Serial.print(buttonState3);
buttonState4 = digitalRead(buttonPin4);
Serial.print(buttonState4);
if(buttonState1 == 1 || buttonState2 == 1){
analogWrite(ena, 160);
analogWrite(enb, 160);
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
delay(200);
if(buttonState3 == 1 || buttonState4 == 1){
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
delay(200);
SonarSensor(trigPin1, echoPin1);
FrontSensor = distance;
if (FrontSensor <= 15){
dir = random(1,3);
Serial.print(dir);
if (dir == 1){
delay(700);
delay(200);
delay(200);
if (dir == 2){
analogWrite(ena, 220);
analogWrite(enb, 220);
delay(700);
delay(200);
delay(200);
else{
analogWrite(ena, 150);
analogWrite(enb, 150);
void SonarSensor(int trigPin,int echoPin){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
