Robot coding issues
I've built a robot that when it encounters an LED light source initiates a State, the way I've done this is to mount a photo resistor on the under chassis of the robot. When the light threshold passes 500 it's meant to initiate the state otherwise move forward and if it encounters an object ahead turns left (defined by the ultrasonic distance sensor). When testing the robot neither states are working, the photo resistor and distance sensor are both working and printing values to the monitor, I've also tested the robot on another code and the distance sensor works fine so I was just wondering if you guys can help me see what I'm missing?
Here's the code:
#include <Servo.h>
// create servo objects
Servo leftMotor;
Servo rightMotor;
const int serialPeriod = 250; // serial print to console every 1/4 second
unsigned long timeSerialDelay =0;
const int loopPeriod = 20;   // ultrasonic period and frequency (50hz)
unsigned long timeLoopDelay =0;
// pins used for ultrasonic sensor,LDR and LED
const int ultrasonic2TrigPin = 8;
const int ultrasonic2EchoPin = 9;
const int ldrPin = A0;
int led = 3;
int ultrasonic2Distance;
int ultrasonic2Duration;
int ldrValue;
#define DRIVE_FORWARD 0   // defined states
#define TURN_LEFT     1
#define MY_STATE      2
int state = DRIVE_FORWARD;
    // ultrasonic sensor pin configurations
    pinMode(ultrasonic2TrigPin, OUTPUT);
    pinMode(ultrasonic2EchoPin, INPUT);
     pinMode(led, OUTPUT);
    leftMotor.attach(13);
    rightMotor.attach(12);
    debugOutput(); // prints debugging messages to the serial console
    if(millis() - timeLoopDelay >= loopPeriod)
        readUltrasonicSensors(); // read and store the measured distances
        readLdr(); // read and store the LDR value
        stateMachine();
        timeLoopDelay = millis();
          digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
void stateMachine()
    if(state == DRIVE_FORWARD) // no obstacles detected
        if(ultrasonic2Distance > 6 || ultrasonic2Distance < 0) // if there's nothing in front of us
            // drive forward
            rightMotor.write(180);
            leftMotor.write(0);
        else if(ldrValue > 500 ) // if an LED is detected
            state = MY_STATE; // My state
            rightMotor.write (90);
            leftMotor.write  (90);
        else // there's an object in front
            state = TURN_LEFT;
    else if(state == TURN_LEFT) // obstacle detected -- turn left
        unsigned long timeToTurnLeft = 500; //  .5 seconds to turn 90 degrees
        unsigned long turnStartTime = millis(); // save the time
        while((millis()-turnStartTime) < timeToTurnLeft) // stay in this loop until timeToTurnLeft (.5 seconds) has elapsed
            // turn left
            leftMotor.write(180);
        state = DRIVE_FORWARD; // revert back to the default state
void readUltrasonicSensors()
    // ultrasonic 2
    digitalWrite(ultrasonic2TrigPin, HIGH);
    delayMicroseconds(10);                  //  keep the trig pin high for at least 10us
    digitalWrite(ultrasonic2TrigPin, LOW);
    ultrasonic2Duration = pulseIn(ultrasonic2EchoPin, HIGH);
    ultrasonic2Distance = (ultrasonic2Duration/2)/29;
void readLdr()
    ldrValue = analogRead(ldrPin);
void debugOutput()
    if((millis() - timeSerialDelay) > serialPeriod)
        Serial.print("ultrasonic2Distance: ");
        Serial.print(ultrasonic2Distance);
        Serial.print("cm");
        Serial.print("ldrValue: ");
        Serial.print(ldrValue);
        timeSerialDelay = millis();
50Hz is a very high rate to be polling your ultrasonics; unless they're very insensitive, you run the risk of picking up returns from previous pings.
what would you recommend, do you think this could be the issue because it runs fine when testing on a simpler code?
