robot library not found in online arduino editor
i have been trying to program a robot to avoid obstacles and move. i came accross this snippet of code online, but when i tried it for myseld, arduino fails to recognise the library even though its present in its examples. whats going on??
#include <ArduinoRobot.h>
#include <Wire.h>
  Robot.begin();
  Robot.motorsWrite(255, 255);
  delay(100);
while this library example is present on editor which also fails to be compiled
 Turn Test
 Check if the robot turns a certain amount of degrees.
 Circuit:
 * Arduino Robot
 created 1 May 2013
 by X. Yang
 modified 12 May 2013
 by D. Cuartielles
 This example is in the public domain
#include <Wire.h>
  // initialize the robot
  Robot.begin();
  Robot.turn(50); //turn 50 degrees to the right
  Robot.motorsStop();
  Robot.turn(-100); //turn 100 degrees to the left
  Robot.motorsStop();
Have You use the IDE library handler to check that that library is present? It doesn't look like that. Maybe You need to download, and/or install it properly?
Please do this:
  • Hover the mouse over the red bar that shows the error message. Click and drag it up so you can see the black console window.
  • Click the icon in the top right corner of the console that looks like two pieces of paper.
  • Paste the error in a message here USING CODE TAGS (</> button on the forum toolbar).
