robot move when detect sound
Hey!Anyone know how to combine this two program in arduino?
1)arduino robot using ultrasonic sensor
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(3, MOTOR12_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
myservo.attach(9);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
delay(5);
void turnRight() {
delay(300);
void turnLeft() {
delay(300);
  1. arduino sound sensor
    int led = 13;
    int threshold = 37;
    int volume;
volume = analogRead(A0);
if(volume>=threshold)
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
What I want is to make the first program activate whenever sound detect.
Please correct your post above and add code tags around your code. [code] // your code here [/code]. it should look like this://your code here
well so what you are saying is that you want the loop not to start until you hear a sound… right?
in that case just put an active wait loop at the end of the setup() waiting for a sound loud enough.
const int threshold = 37;
  myservo.attach(9);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  while (analogRead(A0) < threshold); // blocking wait, do nothing until there is noise
Without knowing what the requirements are for the resulting program? No.
You want init() to run after the hardware has done something? You want to call setup() after something has happened? Neither of those things is going to happen, so you need to make your requirements realistic.
What is to happen when the sound stops? Any level of sound?
Have you tried?
That line just waits for a sound "loud enough" before going into the loop. So if the loop does what you need, then here you go.
(Of course need also the const int threshold = 37; - which is not very high by the way)
