Robot Not Doing what its supposed to
I've written this code from examples ive seen. It compiles and everything but the thing that works is just the LCD screen with the sensor. Motors wont respond to bluetooth commands(using Bluetooth electronics app).
Im using the arduino uno and L298P Shield. Ive testes the motors before, without the bluetooth and they worked. I dont think its something with the way I connected things, but ofcourse that might be a possibility.
Some code explanations. I have a jeep toy that im using. It has 2 motors: first motor is for the front wheels, and it turns the wheels left or right, depending if its running backwards or forwards; second motor runs the back wheels without turning. So thats why I named the motorFront and the motorBack the way I did
Also, dont mind the last case "m", it doesnt exist
EDIT: Pretty sure the bluetooth commands are not sending anything to the arduino. I connected it to the program, but there is no response whatsoever
#include <AFMotor.h>
#include <Wire.h>
//#include <hd44780.h>
#include <hd44780_I2Cexp.h>
#define trigPin 12
#define echoPin 8
hd44780_I2Cexp lcd;
AF_DCMotor motorFront(1, MOTOR12_64KHZ);
AF_DCMotor motorBack(2, MOTOR12_64KHZ);
const int LCD_ROWS = 2;
const int LCD_COLS = 16;
char dataIn = 'S';
char det;
char determinant;
int vel = 255;
int check;
lcd.begin(LCD_COLS, LCD_ROWS);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
motorFront.setSpeed(0);
motorBack.setSpeed(0);
motorFront.run(RELEASE);
motorBack.run(RELEASE);
int duration, distance;
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(100);
  digitalWrite(trigPin, LOW);
  duration = pulseIn(echoPin, HIGH);
  distance =(duration/2) / 29.1;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Atstumas");
  lcd.setCursor(12,0);
  lcd.print(distance);
  lcd.print("cm");
  if (distance >=15)
    lcd.setCursor(0,2);
    lcd.print("Safe Zone :)");
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(" STEP AWAY!!!");
      lcd.setCursor(0,1);
      lcd.setCursor(0,2);
int check();
det = check(); //call check() subrotine to get the serial code
  //serial code analysis
  switch (det){
    case 'F': // F, move forward
    motorBack.setSpeed(vel);
    motorBack.run(FORWARD);
   // motorFront.run(FORWARD);
    det = check();
case 'B': // B, move back
    motorBack.run(BACKWARD);
    //motorLeft.run(BACKWARD);
    det = check();
 case 'L':// L, move wheels left
    motorFront.setSpeed(vel);
    det = check();
case 'R': // R, move wheels right       //FORWARD kol kas yra i kaire, BACKWARD yra i desine
    motorFront.run(BACKWARD);
    det = check();
   case 'I': // I, turn right forward
    motorBack.setSpeed(vel/2);
    det = check();
case 'J': // J, turn right back
    det = check();
    case 'G': // G, turn left forward
    det = check();
 case 'H': // H, turn left back
    det = check();
 case 'S':
   // S, stop
    det = check();
case 'b':
  //obstacle avoider robot
   motorFront.setSpeed(vel); //set the speed of the motors, between 0-255
   motorBack.setSpeed (vel);
  long Aduration, Adistance; // start the scan
  delayMicroseconds(2); // delays are required for a succesful sensor operation.
 delayMicroseconds(10); //this delay is required as well!
  Aduration = pulseIn(echoPin, HIGH);
  Adistance = (Aduration/2) / 29.1;
if (Adistance < 25)
{ motorFront.setSpeed(vel);
    motorFront.run(FORWARD);  // Turn as long as there's an obstacle ahead.
    motorBack.run (FORWARD);
 else {
   delay (15);
   motorFront.run(RELEASE); //if there's no obstacle ahead, Go Forward!
int check(){
  if (Serial.available() > 0){// if there is valid data in the serial port
  dataIn = Serial.read();// stores data into a varialbe
//check the code
    if (dataIn == 'F'){//Forward
      determinant = 'F';
    else if (dataIn == 'B'){//Backward
      determinant = 'B';
    else if (dataIn == 'L'){//Left
      determinant = 'L';
    else if (dataIn == 'R'){//Right
      determinant = 'R';
    else if (dataIn == 'I'){//Froward Right
      determinant = 'I';
    else if (dataIn == 'J'){//Backward Right
      determinant = 'J';
    else if (dataIn == 'G'){//Forward Left
      determinant = 'G';
    else if (dataIn == 'H'){//Backward Left
      determinant = 'H';
    else if (dataIn == 'S'){//Stop
      determinant = 'S';
    else if (dataIn == '0'){//Speed 0
      vel = 0;
    else if (dataIn == '1'){//Speed 25
      vel = 25;
    else if (dataIn == '2'){//Speed 50
      vel = 50;
    else if (dataIn == '3'){//Speed 75
      vel = 75;
    else if (dataIn == '4'){//Speed 100
      vel = 100;
    else if (dataIn == '5'){//Speed 125
      vel = 125;
    else if (dataIn == '6'){//Speed 150
      vel = 150;
    else if (dataIn == '7'){//Speed 175
      vel = 175;
    else if (dataIn == '8'){//Speed 200
      vel = 200;
    else if (dataIn == '9'){//Speed 225
      vel = 225;
    else if (dataIn == 'b'){//Extra On
      determinant = 'b';
    else if (dataIn == 'm'){//Extra On
      determinant = 'm';
  return determinant;
Break the problem into standalone parts.
  1. Make sure that you understand how bluetooth works and that you are sending and receiving the commands you expect.
  2. Make sure that the robot works as expected, when your program gives it certain commands.
  3. Put 1. and 2. together.
