I am thinking of a way to keep a robot within the boundaries of a large property. this is not about determining longitude and latitude, this is about determining position relative to the property boundaries. not concerned with the vehicles heading, that's a different project.
the first stage, a proof of concept test, would go like this:
The Venue Infrastructure
- A rectanglular flat floor.
- A pole at each corner
- An IR LED strip at each pole, mounted vertically
- LED strips connected to any random IR remote, which has a switch to keep it transmitting one command constantly.
the only requirement from the remotes is that each one transmits a different bit sequence than the others.
The Robot Infrastructure:
- a flat platform on top
- with a stepper motor
- spinning a parabolic mirror, half a pipe, not a dish, with an IR sensor at the focus
the plan is:
- mirror spins, reads what LED string A puts out, notes stepper position
- mirror continues to spin, reads what LED string B puts out, notes stepper position
- mirror continues to spin, reads what LED string C puts out, notes stepper position
- mirror continues to spin, reads what LED string D puts out, notes stepper position
then you do some surveyor trigonometry and calculate where you are in the rectangle, based on the angles to the sensors.
My questions:
- could you modulate an LED strip with the 38khz from an IR remote?
- could you read that quick enough to make things work? I am thinking 1 - 10 RPM for the stepper motor
- has anyone tried a parabolic reflector with an IR sensor, to determine the range available?
- has anyone tried making an IR sensor strip, to increase the chance of catching a signal?
