The project is a simple 3 wheel robot.
two traction wheels (two nema17) and one free --- Controller motors are DRV8825
a friend programmed me the arduino Uno
the robot is managed by a control with protocol S.bus (radiolink AT10)
the robot responds, but not well
there is loss of steps, and great vibrations in the step motors
the movement is not correct.
to test the electronics and the correct amount of current I loaded in arduino a tester of step motors, and the motors moved perfectly without vibrations and without losing steps
the code
#include <sbus.h>
// used pins
#define SBUS_PIN 3 // D3
SBUS sbus;
int dirA = 12;
int stepA = 13;
int dirB = 10;
int stepB = 11;
//Serial.begin(115200);
pinMode(dirA, OUTPUT);
pinMode(stepA, OUTPUT);
pinMode(dirB, OUTPUT);
pinMode(stepB, OUTPUT);
//sbus.begin(SBUS_PIN, sbusNonBlocking);
sbus.begin(SBUS_PIN, sbusBlocking);
unsigned long currentTime = 0;
const int maxPulses = 70;
const int minPulses = 1;
const int minAnalogStart = 1400;
const int minAnalogEnd = 1000;
const int maxAnalogStart = 1600;
const int maxAnalogEnd = 2000;
int currChannel1 = 0; //joystick derecho, eje horizontal
int currChannel2 = 0; //joystick derecho, eje vertical
int currChannel3 = 0; //joystick izquierdo, eje vertical (throotrle)
int currChannel4 = 0; //joystick izquierdo, eje horizontal (throotrle)
int currChannel5 = 0; //llave izquierda abajo abajo
int currChannel6 = 0; //
int currChannel7 = 0; //
int currChannel8 = 0; //
int currChannel9 = 0; //llave izquierda frente derecha
int currChannel10 = 0; //llave izquierda frente izquierda
int currChannel11 = 0; //llave derecha frente derecha
// Check whether we keep receving data, or we have a connection between the two modules
currentTime = millis();
//if (sbus.signalLossActive() == false && sbus.failsafeActive() == false)
if (sbus.waitFrame() == true)
currChannel1 = sbus.getChannel(1); //joystick derecho, eje horizontal
currChannel2 = sbus.getChannel(2); //joystick derecho, eje vertical
currChannel3 = sbus.getChannel(3); //joystick izquierdo, eje vertical (throotrle)
currChannel4 = sbus.getChannel(4); //joystick izquierdo, eje horizontal (throotrle)
currChannel5 = sbus.getChannel(5); //llave izquierda abajo abajo
currChannel6 = sbus.getChannel(6); //
currChannel7 = sbus.getChannel(7); //
currChannel8 = sbus.getChannel(8); //
currChannel9 = sbus.getChannel(9); //llave izquierda frente derecha
currChannel10 = sbus.getChannel(10); //llave izquierda frente izquierda
currChannel11 = sbus.getChannel(11); //llave derecha frente derecha
//if (sbus.signalLossActive())
// Serial.print("SIGNAL_LOSS ");
//if (sbus.failsafeActive())
// Serial.print("FAILSAFE");
int motorPulsesA = 0;
int motorPulsesB = 0;
// Y-axis used for forward and backward control
if (currChannel2 < minAnalogStart)
// Set Motor A backward
digitalWrite(dirA, HIGH);
// Set Motor B foward
digitalWrite(dirB, LOW);
// Convert the declining Y-axis readings for going backward from 110 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorPulsesA = map(currChannel2, minAnalogEnd, minAnalogStart, maxPulses, minPulses);
motorPulsesB = motorPulsesA;
else if (currChannel2 > maxAnalogStart)
// Set Motor A forward
digitalWrite(dirA, LOW);
// Set Motor B forward
digitalWrite(dirB, HIGH);
// Convert the increasing Y-axis readings for going forward from 140 to 255 into 0 to 255 value for the PWM signal for increasing the motor speed
motorPulsesA = map(currChannel2, maxAnalogStart, maxAnalogEnd, minPulses, maxPulses);
if (currChannel1 < minAnalogStart)
motorPulsesA = map(currChannel1, minAnalogEnd, minAnalogStart, maxPulses, minPulses);
else if (currChannel1 > maxAnalogStart)
// Set Motor B backward
motorPulsesA = map(currChannel1, maxAnalogStart, maxAnalogEnd, minPulses, maxPulses);
if ((currChannel2 < minAnalogStart || currChannel2 > maxAnalogStart) && (currChannel1 < minAnalogStart || currChannel1 > maxAnalogStart))
int xMapped = map(currChannel1, minAnalogEnd, minAnalogStart, maxPulses, minPulses);
motorPulsesA += xMapped;
motorPulsesB -= xMapped;
if (motorPulsesA > maxPulses)
motorPulsesA = maxPulses;
if (motorPulsesB < minPulses)
motorPulsesB = minPulses;
int xMapped = map(currChannel1, maxAnalogStart, maxAnalogEnd, minPulses, maxPulses);
motorPulsesA -= xMapped;
motorPulsesB += xMapped;
if (motorPulsesA < minPulses)
motorPulsesA = minPulses;
if (motorPulsesB > maxPulses)
motorPulsesB = maxPulses;
int pulses;
for (pulses = minPulses; pulses<=maxPulses; pulses++)
if (motorPulsesA >= pulses)
digitalWrite(stepA, HIGH); // Send HIGH (STEP) signal to motor A
if (motorPulsesB >= pulses)
digitalWrite(stepB, HIGH); // Send HIGH (STEP) signal to motor B
delayMicroseconds(2);
digitalWrite(stepA, LOW); // Send LOW signal to motor A
digitalWrite(stepB, LOW); // Send LOW signal to motor B
delayMicroseconds(900);
Serial.print("ch1: ");
Serial.print(currChannel1);
Serial.print(" - ch2: ");
Serial.print(currChannel2);
Serial.print(" - ch3: ");
Serial.print(currChannel3);
Serial.print(" - ch4: ");
Serial.print(currChannel4);
Serial.print(" - ch5: ");
Serial.print(currChannel5);
Serial.print(" - ch6: ");
Serial.print(currChannel6);
Serial.print(" - ch7: ");
Serial.print(currChannel7);
Serial.print(" - ch8: ");
Serial.print(currChannel8);
Serial.print(" - ch9: ");
Serial.print(currChannel9);
Serial.print(" - ch10: ");
Serial.print(currChannel10);
Serial.print(" - ch11: ");
Serial.print(currChannel11);
//Serial.println();
//delay(200);
I hope you can help me - thanks
