Hello world!
I’m new to programming in any language, but I have managed to figure out just enough to get started on a remote-controlled robot. So far I have an Arduino Fio with an Xbee acting as a controller, transmitting analogread values via Bill Porter’s EasyTransfer library to an Arduino Mega 2560 with another Xbee. The Mega takes in these values, maps them to servo angles, and puts out servo pulses to a Sabertooth 2x25 motor driver. My main concern right now, before I develop this project further and put in the other dozen functions is safety. I do not want my robot wandering off if it loses communication with the controller. Right now, the vehicle has so little code on it that if it loses signal, the servo outputs keep putting out the same signal to the motor driver until it receives instructions again. I started to make a safety routine based on comparing differences in millisecond count, but there the problems started getting worse. On the transmitter, I have a millis() count sent through to the receiver, and the receiver is supposed to store that value, compare it to the old value, and if they are not the same, execute the code that takes in the analogread values and puts out mapped servo values. If those two millis() values compared turn out to be the same, it is supposed to write 90 to all servo outputs and wait until the two compared milllis() are different again.
What actually happens is that the value is read in, stored, and the comparison and value shift are seemingly ignored, and the program returns to the top after the comparison.
controller side
#include <EasyTransfer.h> //Bill Porter's EasyTransfer library
EasyTransfer ET;
struct SEND_DATA_STRUCTURE{
int drive; //the values to be sent once something is written to them
int steer;
int dome;
int safenum;
int toggle;
SEND_DATA_STRUCTURE directions;
void setup(){
Serial.begin(9600); //theres only one serial port on the transmitting device
ET.begin(details(directions), &Serial); //setup of the library (variable group and serial port number)
pinMode(A0, INPUT); //analog pins set to input, reading knobs
pinMode(A1, INPUT);
pinMode(A2, INPUT);
toggle = 1;
void loop(){
directions.drive = analogRead(A0); //directions group, variable drive
directions.steer = analogRead(A1); //directions group, variable steer
directions.dome = analogRead(A2); //directions group, variable dome
directions.safenum = millis();
ET.sendData(); //tells the library to assemble and fire off the data
delay(40);
and receiver side
#include <Servo.h> //the Servo library for making output pins
//act like airplane receiver channels
EasyTransfer ET;
struct RECEIVE_DATA_STRUCTURE{
int drive; //library's internal
int steer; //values it is receiving
int dome; //in the serial port
int safenum;
int driveout; //values for shuffling stuff after reception
int steerout;
int domeout;
int midhi = 560;
int midlo = 464;
Servo spedo; //servo representing drive
Servo drivo; //servo representing steer
Servo domo; //servo representing dome (head) rotation
int safeold = 1;
int safenew = 0;
RECEIVE_DATA_STRUCTURE directions;
void setup(){
Serial.begin(9600); //for monitoring
Serial1.begin(9600); //this is the port it receives instructions on
ET.begin(details(directions), &Serial1); //telling the library
//what set of values it is receiving and what serial port to watch
spedo.attach(12); //attaching servo objects to output pins
drivo.attach(11);
domo.attach(10);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
Serial.println("center");
spedo.write(90);
drivo.write(90);
domo.write(90);
delay(2000);
/*Serial.println("low");
spedo.write(0);
drivo.write(0);
domo.write(0);
delay(2000);
Serial.println("high");
spedo.write(179);
drivo.write(179);
domo.write(179);
delay(2000);
digitalWrite(13, LOW);
void loop(){
if(ET.receiveData()){
//mapping values from 0 to 1023 to servo angles of 0 to 179
//driveout = map(directions.drive,0,500,0,89)
// and ,524,1023,90,179)
Serial.println("run 1");
delay(100);
Serial.print("safenum 1 =");
Serial.println((directions.safenum));
Serial.print("safenew 1 =");
Serial.println((safenew));
Serial.print("safeold 1 =");
Serial.println((safeold));
(directions.safenum = safenew);
Serial.print("safenum 2 =");
Serial.print("safenew 2 =");
Serial.print("safeold 2 =");
delay(100);
Serial.println("run 2");
(safeold = safenew);
Serial.print("safenum 3 =");
Serial.print("safenew 3 =");
Serial.print("safeold 3 =");
delay(100);
if (safeold != safenew){
Serial.println("run 3");
Serial.print("safenum 4 =");
Serial.print("safenew 4 =");
Serial.print("safeold 4 =");
delay(100);
if (directions.drive <= midlo){
driveout = map(directions.drive,0,midlo,0,89);
else if (directions.drive >= midhi){
driveout = map(directions.drive,midhi,1023,90,179);
else driveout = 90;
//driveout = map(directions.drive,0,1023,0,179);
if (directions.steer <= midlo){
steerout = map(directions.steer,1023,midlo,0,89);
else if (directions.steer >= midhi){
steerout = map(directions.steer,midhi,0,90,179);
else steerout = 90;
//steerout = map(directions.steer,0,1023,0,179);
Serial.println("run 4");
if (directions.dome <= midlo){
domeout = map(directions.dome,0,midlo,0,89);
else if (directions.dome >= midhi){
domeout = map(directions.dome,midhi,1023,90,179);
else domeout = 90;
//domeout = map(directions.dome,0,1023,0,179);
Serial.println("run 5");
Serial.print("speed = "); //debugging statements
Serial.print((driveout));
Serial.print("direction = ");
Serial.print((steerout));
Serial.print("dome = ");
Serial.println((domeout));
spedo.write(driveout); //telling the servo objects to do their thing
drivo.write(steerout);
domo.write(domeout);
else{
return;
//oldval = val
//val = safetything
//if oldval != val
//do stuff
