I'm looking to undertake an ambitious project, which would be to design and build a hexapod that will be capable of self-righting, similar to the Spot robot from Boston Dynamics.
My main question is about the difficulty of programming this functionally. I hear of terms like inverse kinematics and inverse dynamics, and I'd like to know what I'd need to learn in order to be able to create the program. Similarly, I have no clue about whether cheap hobby servos would be sufficient to build such a robot, or whether I would need something more specialized.
Extremely difficult, so start at the beginning. Just getting a hexapod to walk smoothly and with minimum energy expenditure is an interesting and popular challenge, so that is one place to start on the learning curve.
Hint: the search terms "hexapod gait analysis" will turn up lots of research and discussion.
Probably not, for inverse kinematics calculations. You can easily determine that by experimenting with a single leg mechanism.
I see. So in that case, what hardware would I need once I get to the point where I'm able to program a self-balancing robot?
Look on the web to see what others have done. There are countless hexapod project posts.
I suggest to get some practical experience by building a leg mechanism and determining for yourself whether its performance will be satisfactory for the project.
