Hello , I'm just working on a little project, creating a little robot kind of thing out of things I already have at home and was wondering if someone could check if my code was feasible. Right now I'm just trying to set up some kind of sequence for it to turn (I'm just using a motor driver and motors)
Theres 2 motors (a and b) and they have pins set so that one of them is forward and the other is back (f and b respectively)
Heres what I have so far: (I still have to do some testing as to what time intervals will be best in order to have it turn the right degrees and such)
int motoraf = 5;
int motorab = 6;
int motorbf = 10;
int motorbb = 11;
const long eventTime = 2000;
const long eventTime_2 = 6000;
bool turn = false;
unsigned long previousTime = 0;
pinMode(motoraf, OUTPUT);
pinMode(motorab, OUTPUT);
pinMode(motorbf, OUTPUT);
pinMode(motorbb, OUTPUT);
digitalWrite(motoraf, HIGH);
digitalWrite (motorbf, HIGH);
if (turn == true) {
unsigned long Ms = millis();
digitalWrite(motoraf, LOW);
digitalWrite(motorbf, LOW);
digitalWrite(motorab, HIGH);
digitalWrite(motorbb, HIGH);
if (Ms - previousTime >= eventTime){
previousTime = Ms;
digitalWrite(motorab, LOW);
digitalWrite(motorbb, LOW);
digitalWrite(motorbf, HIGH);
previousTime = Ms;
if (Ms - previousTime >= eventTime_2){
previousTime = Ms;
if (Ms - previousTime >= eventTime{
previousTime = Ms;
bool turn = false
i don't see how the 2nd test of Ms - previousTime >= eventTime can ever be true since previousTime is just set to Ms
seems like you should have a state machine and a timer which advances the state each time the timer expires. each state can set the directions (speed?) of the motors
consider
#define MaxState = 3
int state;
#define Period 1000
unsigned long msecLst;
void
loop ()
unsigned long msec = millis ();
if ((msec - msecLst) < Period)
return;
msecLst = msec;
switch (state) {
case 0:
Serial.println ("state 0");
state++;
case 1:
Serial.println ("state 1");
state++;
case 2:
Serial.println ("state 2");
state = 0;
void setup () {
Serial.begin (9600);
Thanks for the help, with the state machine and timer would something like this be fitting?
int MaxState = 4
int state;
unsigned long Period = 1000;
int motoraf = 5;
int motorab = 6;
int motorbf = 11;
int motorbb = 12;
//is it time to proceed to the next part of the code?
//no it isn't
return;
//now it is
msecLst = msec;
//stating the code
switch (state) {
case 0: //first part it should do
digitalWrite(motorab, HIGH); //left wheel going backwards
digitalWrite(motorbb, HIGH); //right wheel going backwards
Period = 2000UL; //time it should go backwards for
state++; //adds 1 to the value of state so it can go to the next one
case 1:
digitalWrite(motorab, LOW); //stops left wheel going back
digitalWrite(motorbb, LOW); //stops right wheel going back
digitalWrite(motorbf, HIGH); //makes only right wheel go forward
Period = 2000UL; //time the right wheel should turn for, should make body go left
state++;
case 2:
digitalWrite(motoraf, HIGH); //makes left wheel join the right, should make rover go forward normally
Period = 6000UL; //time it should take going forward (away from obstacle)
state++;
case 3:
Serial.println ("state 3");
digitalWrite(motorbf, LOW); //stops turning right wheel forward (left wheel turning so it should turn left back into original position)
Period = 2000;; //time it should take turning back into og rotation
state = 0;
