Robot with camera recognized
hello
I have a big issue with my project. I am developing a robot which can see with a camera, I am starting so, I have a camera model CF0706C-V1 TTL Serial Camera Module, with the IC vc0706preb, which is the usual IC for cameras for adafruit library.
My problem is that I am trying to communicate with the camera but this one is not responding as suppose to do it.
see my code
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(10, 11); // RX, TX
void setup(){
Serial.println(“reset camera”);
// set the data rate for the SoftwareSerial port
pinMode(10, INPUT);
pinMode(11, OUTPUT);
mySerial.begin(115200);
while(!mySerial.available()){
Serial.println(“en espera”);
delay(45000);
void loop(){
mySerial.println(86, HEX);
mySerial.println(00, HEX);
mySerial.println(38, HEX);
char dato = mySerial.read();
Serial.print(dato, HEX);
//mySerial.print(1, HEX);
as you can see I am just sending reset instruction and waiting for the normal respond 76xx26xx but I not getting that, instead I getting this:
56 43 30 37 30 33 20 31 2E 30 30 DA 43 74…FFFFFF
can some one help me?
thank you.
VC0703 1.00
Please remember to use code tags when posting code
hi
thanks for reply. I didn't think to convert to ascii, I converted all the message...
VC0703 1.00ÚCtrl infr existÚUser-defined sensorÚ625ÚIgit en
have any idea why is sending this?
thanks
