//Motortest med fire DC motorer
const int LED_PIN = 13;
const int speed1 = 100; // percent maximum speed
#define echoPin A5
#define trigPin A4
int maximumRange = 200;
int minimumRange = 0;
long duration, distance;
#include <AFMotor.h> //adafruit motor shield library
AF_DCMotor Motor_Left_Front(4, MOTOR34_1KHZ); // Motor 4
AF_DCMotor Motor_Right_Front(3, MOTOR34_1KHZ); // Motor 3
AF_DCMotor Motor_Left_Rear(1, MOTOR34_1KHZ); // Motor 1
AF_DCMotor Motor_Right_Rear(2, MOTOR34_1KHZ); // Motor 2
int pwm;
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
// scale percent into pwm range (0-255)
pwm = map(speed1, 0, 100, 0, 255);
Motor_Left_Front.setSpeed(pwm);
Motor_Right_Front.setSpeed(pwm);
Motor_Left_Rear.setSpeed(pwm);
Motor_Right_Rear.setSpeed(pwm);
// run over and over
digitalWrite(trigPin,LOW);
delayMicroseconds(2);
digitalWrite(trigPin,HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin,HIGH);
distance = (duration/2) / 29.1;
if (distance>=20){
// put your main code here, to run repeatedly:+
Serial.println("rotate cw");
Motor_Left_Front.run(FORWARD);
Motor_Left_Rear.run(FORWARD);
Motor_Right_Front.run(FORWARD);
Motor_Right_Rear.run(FORWARD);
else{
Motor_Left_Front.run(BACKWARD);
Motor_Right_Front.run(BACKWARD);
/*delay(5000); // run for 5 seconds
Serial.println("stopped");
Motor_Left_Front.run(RELEASE); // stop the motors
Motor_Right_Front.run(RELEASE);
Motor_Left_Rear.run(RELEASE); // stop the motors
Motor_Right_Rear.run(RELEASE);
delay(5000); // stop for 5 seconds
this is my code
so with battery it will just only drive sometimes… cant figure out why… i have tried to change battery and the uno board but it wont work… you guys are my last hope
just ignore the wire that got loose from the one wheel… gonna fix that while im writing this… but when the wire is ACTUALLY CONNECTED TO THE WHEEL i still have problems
