I've been interested in robotic arms for a good long while. When I saw the "open source" U-Arm, I became a bit rabid. Unfortunately, UFactory got funding and clammed up. Disappointing. Then teocreo got irritated and designed his own. He promised to send me DXF and DWG files of it after he made 3 or 4 changes. He needed an Inverse Kinematic sketch to run it with. I found one that was open source, so I sent it to him. I haven't heard from him since.
I ordered MG996R Metal Gears Digital RC Servo Motor
http://www.ebay.com/itm/181297738322?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
and bought a lazy susan ball bearing unit (not very good, but good enough for a first experiment),
1/8" birch plywood, 1/4" birch plywood, already have micro servos, arduino 2560 mega, and a lot of the other stuff I'll need.
I contacted Lebanon High School and the technical teacher said the school has a laser cutter and CNC machine that I can use. He is the instructor for Autocad, so we can do the drawings needed.
I have the program, which I will need help from you folks to adapt and improve on.
The first arm will be made of the aforementioned plywood. It probably won't be particularly great, but, with your help, we can improve it.
Eventually, it will evolve into something aluminium based that can be CNC'd or printed, glued to aluminium and bandsawn, jig sawn, or something like that. Not everyone has access to CNC machines.
On the other hand, did you notice that I am getting free access to HIGH SCHOOL equipment? Bet you could too. Ask. I did promise to include the kids in on the project, if they want.
I am kind of thinking about sponsoring a class project of making a robotic arm sitting on a robot car serving a soft drink to the teacher sitting on a chair in the basketball court at half-time. The robot operator being the student who contributes the most to the project.
But I diverge.
I plan to make a plywood box base sitting on a lazy susan bearing which has a little bit of slop in it. A plywood turntable with an MG996R servo to rotate it and a U-bracket of plywood or bent up aluminium sheet to hold the upper arm.
Plywood box upper arm (humerus). 1/8" sides, 1/16" top and bottom, glued on. Probably 3/4" or 1" cross section.
3/16" pivot bolts. Grease the wood holes. That's the bearing. (It's a toy, not production equipment).
Wood block glued to the inside of the arm to attach the MG996R servo to at the pivot point.
Plywood box lower arm(ulna). Same construction.
Same pivot.
Push-pull rod to the lower arm to flex it.
MG996R servo attached to the bottom of the upper arm push-pulling an extension of the elbow to move the lower arm.
Springs at the joints to offset some of the arm weight.
Micro servo to rotate the wrist up and down.
Micro servo to spin the gripper.
Micro servo to operate the gripper.
A lot of the details are not yet resolved - most actually.
I have some 6063-T3 aluminium left over from when I built my airplane (Baby Great Lakes). I will probably use some to make brackets and such.
I desperately need plans for a gripper. I have no idea whatsoever how to build such a thing. I do have a CNC machine available, however.
The plywood I have is 12" x 12", so I will have to stay within that range. I'm guessing 250mm pivot points.
I will post anything and everything that I come up with. I will lean heavily on the members for advice. I have my own website, so I can post everything there if I can remember how to set it up. It's been several years since I monkeyed around with it. www.reckelfamily.com
I'll get started on it Monday or Tuesday.
John
