thomas3120:
Thanks for the reply cr0sh.
Well, just thought about this last night. Definitely not on a 'caterpillar' machinary scale hehe.
Ok - then -what- scale? What would be the smallest minimum and fully extended lengths you are looking for?
thomas3120:
I was thinking of using possibly 2 hydraulic (oil, not water) pistons to control the upper arm and lower arm portions.
I would need a hydraulic (oil) pump, motor to run the pump, a 'hydraulic line seperator'...to keep the movements independent.
Also(eventually) probably some type of electronic control/microcontroller to control each hydraulic piston.
Just be aware of a few things:
- This stuff isn't cheap
- It is messy and not very easy to assemble (hydraulic oil isn't fun stuff, either)
- It typically isn't small
- Did I mention it's not cheap?
I've never really shopped around for such components - you'd probably want to look at Grainger or McMaster-Carr, places like that, to get an idea of what you are looking for. Whether they have the sizes you need or not is another question, because they deal mainly with industrial needs. Generally, when you get below a stroke length of about 8 inches or so, you start getting into pneumatics or electro linear acutators, as there isn't typically much call for the capabilities of hydraulics (there's also the possibility of electro-hydraulic actuators - if you have the money).
A hydraulic system, from what I have read about, is a fairly complex and expensive system. It is a system which, if there is a failure of a component, is going to leak hot and potentially caustic fluid under pressure (pressure high enough to penetrate skin or worse). This is not an indoor project.
thomas3120:
This part of my project is still a good ways away...no hurry. Just like to start looking at different concepts using oil hydraulics and products. So no rush and any advice is greatly appreciated
You might look into other options; I don't know what your minimum sizing is, but some pneumatic cylinders can be run as low-pressure hydraulics with the appropriate fluids (the manufacturer of the cylinders will specify whether they can be used in this manner or not, and what to use). Pneumatic cylinders tend to be smaller, but you can't run -any- such cylinder as a hydraulic; the fluid must be compatible with the seals (o-rings and such), otherwise leaks and failure will occur.
Other possible options (again, depending on needs and scale) would be to homebrew your own cylinders, etc - and/or use syringes (you see this occasionally on small-scale model hydraulic systems).
