Thanks steve!
I was actually basing my original script of the of example 3 from that series. My final code looks like the following:
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
int xInt = 0;
int yInt = 0;
boolean newData = false;
Serial.println("Enter data in this style <xxx, yyy> ");
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // this continues where the previous call left off
xInt = atoi(strtokIndx); // convert this part to an integer
strtokIndx = strtok(NULL, ",");
yInt = atoi(strtokIndx); // convert this part to a float
void showParsedData() {
Serial.print("XVal ");
Serial.println(xInt);
Serial.println(yInt);
I will probably get rid of all serial prints and instead use the values to control my steppers.
