Hi all,
I am sort of new to the Arduino world, my only other project to date is a hidden bookshelf door where with the pull of a book the Arduino fires a linear actuator for a certain time then delays and reverses...so not much coding.
I am starting now to work on my "Robotic Bartender". Basically I am looking to send a simple code from an app to the Arduino to then fire a sequence of motors depending on the code received but I cannot get the app to connect to the board to fire the sequence. I can get the sequence to go in a basic loop so I know the wiring is correct it's just something with the communication.
Below is the code I have so far as the test run and will build from there once I figure out the connection problem.
int input = 0;
// These constants won't change:
const int RUM = 13; //
const int COKE = 12; //
const int DIETCOKE = 12;
pinMode(RUM, OUTPUT);
pinMode(COKE, OUTPUT);
pinMode(DIETCOKE, OUTPUT);
//check if there's incoming data,
if(Serial.available() > 0){
//if so, then read the incoming data.
input = Serial.read();
//make different colours depending on the input value
if(input == '1'){
digitalWrite(RUM, HIGH);
delay(2000);
digitalWrite(COKE, HIGH);
delay(5000);
digitalWrite(RUM, LOW);
digitalWrite(COKE, LOW);
else if(input == '2' ){
delay(2000);
digitalWrite(DIETCOKE, HIGH);
delay(5000);
digitalWrite(DIETCOKE, LOW);
What kind of app do you want to connect to the Arduino, and how? If your code works with the Serial Monitor, you have to make the app connect to the Arduino COM port.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Do you realize you have Coke and Diet Coke as the same output pin number?
Thanks.. Tom..
DrDiettrich:
I was trying with both the MIT app inventor and thunkduino. I guess I am having trouble with getting apps to send via com port.
Opps added the diet coke at the last second to show a second option and didn't see I put the wrong pin, updated code below
int input = 0;
const int DIETCOKE = 11;
if(input == '1'){
delay(2000);
delay(5000);
delay(2000);
delay(5000);
What Bluetooth device are you using, do you get it to pair with your phone?
Thanks.. Tom..
TomGeorge:
Thanks.. Tom..
I'm not using Bluetooth, just using usb connection
As asked earlier, does it work using the Arduino IDE monitor?
Can your phone/tablet see the com port?
Does the phone/tablet recognise that something has been plugged in when you physically connect to it?
What model Arduino?
Thanks.. Tom..
TomGeorge:
What model Arduino?
Thanks.. Tom..
Not sure what you mean by working on the IDE monitor.
My phone recognizes something is there but that's about it.
The most connection i got was with the windows remote arduino experience app on my tablet but all i was able to do was turn on and off individual pins.
I'm working with an Arduino uno.
jdilucente:
The IDE you program the UNO with has a "Monitor" facility that connects to the com port you programmed through and will let you send and receive data on the comm port.
Select "TOOLS" then "SerialMonitor"
When its window opens, select the baud rate that you have Serial.begin set at in your program,
You can then send your 1 or 2 commands in the top send window.
It is invaluable for debugging as Serial.print statements in the code, send data to the receive window of the IDE.
https://learn.adafruit.com/adafruit-arduino-lesson-5-the-serial-monitor?view=all
Tom..
