Hello,
A good friend of mine who is a brilliant engineer has a lifestyle block just out of town. His ride on lawn mower just gave up the ghost, and while at the local lawnmower shop having a look around, he saw one of these robotic lawnmowers that drives around and docks to charge etc.
He gave me a call inquiring what I thought of the idea, effectiveness on his property etc, and the conversation ended up that we would build one.
His property is probably around 2000m2 in size, the part he wants to mow anyway. He is there for the long term, so having a system that is portable to another property isn't really required.
We thought about running (and burying) a inductive loop zig zagged throughout the area he wants to mow, so the mower effective is just a line follower. I however haven't used inductive type loops before, nor attempted to read one through soil. Does anyone know how effective this will be?
The mower he is going to design and build will most likely have a 1m cutting diameter, not one of these small ones that takes all week to mow a property.
I had toyed with the ideas:
GPS with set pattern.
Boundary wire and random pattern.
Boundary wire with random pattern with a couple of inductive loops for hard to drive areas which it would then follow.
Some sort of buried grid
etc
But out of all of these, the inductive loop buried slightly under the surface sounded the most feasible, esp when its not needed on any other properties.
Auto docking etc wont be a problem, I have an idea for that already. Its just the method of driving a known path and what is going to be the easiest or the most effective to do.
Has anyone detected an inductive loop buried before?
As I say in the title, this is not just a dream - it is going to happen in the next month or so as his lawnmower died and is very keen to pursue. His home workshop is better equipped than most engineering firms in town, so building something wont be an issue - he is very talented in the workshop also.
I may use just a 644P or maybe a 1284P and take advantage of the extra RAM - if its warranted. Else a standard 328 or something may be fine. It wont really matter, it will be on a custom made board etc.
Any input or ideas would be great, and any info on inductive loops would be appreciated.
Regards
James
