robotics car
Hello I am a middle school stem club student working on a project and am having problems with this code. We are having problems with libraries and declaring the variable obstacle. Anything would help!!!!
// Autonomous_RC: Sketch to control an autonomus race car that will loop in an oval closed race track
// the car will maintain a pre-set distance from the fence of the track using an ultrasonic sensor to range the distance
// Designed and developed by Juan and Juan Loreto on April of 2015
// Version 0.33
// Copyright (c) <2015>, <Horsepower & Iditarod>
// All rights reserved.
// Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
// 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
// 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer
// in the documentation and/or other materials provided with the distribution.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
// BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
// SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
// DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
// OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Libraries to be used in this sketch
#include <Servo.h>
#include <NewPing.h>
#include <PID_v1.h>
// Constants definitions
// PIN assignment for ultrasonic sensor (have to be DIGITAL pins)
#define S1_TRIGGER_PIN 7
#define S1_ECHO_PIN 6
#define S2_TRIGGER_PIN 5
#define S2_ECHO_PIN 4
// PIN assignment for steering servo (has to be PWM pin)
#define STEERING_SERVO_PIN 10
// PIN assignment for ESC (has to be PWM pin)
#define ESC_SERVO_PIN 11
// Tuning values
#define KP 1 // this is the gain for Proportional correction
#define KI 0.75 // this is the gain for Integral correction
#define KD 0.50 // this is the gain for Derivative correction
#define DISTANCE_FROM_OBSTACLE 100 // this is the max distance from a wall in front
#define SONAR_MAX_DISTANCE 200 // this is the maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define STEER_LEFT_VALUE 130 // this is the value to completely turn left
#define STEER_RIGHT_VALUE 50 // this is the value to completely turn right
#define STEER_CENTER 90 // this is the value to completely center the front wheels
#define STEER_RIGHT_END_TURN 70 // this is the turn to right after the turn
#define MAX_SPEED 179 // this is the value of the highest speed
#define STOP 90 // this is the value to stop the motor
#define TURN_SPEED 97
#define CRUISE_SPEED 100 // this is the value of the cruise speed
#define GET_READY 5000 // this is the time we want the car to wait while we set it up after power it on (milliseconds)
#define RACE_TIME 60000 // this is the time the car will be running in the track (milliseconds)
// Variables definition
double Setpoint, Input, Output, obstacle; // This variables are required by the PID library, the 3 k variables are initialized with the tuning values;
unsigned long iinitialTime, currentTime;
boolean run, debug, turn;
// Objects definition
Servo steering, esc; // This line creates two objects of the type Servo, one for the steering servo and one for the ESC.
NewPing sonarS(S1_TRIGGER_PIN, S1_ECHO_PIN, SONAR_MAX_DISTANCE); // NewPing setup of pins and maximum distance for side ultrasonic sensor
NewPing sonarF(S2_TRIGGER_PIN, S2_ECHO_PIN, SONAR_MAX_DISTANCE); // NewPing setup of pins and maximum distance for front ultrasonic sensor
Serial.begin(9600); // Open serial monitor at 115200 baud to send information.
// Links the Servo objects with the PINS on the Arduino board
steering.attach(STEERING_SERVO_PIN);
esc.attach(ESC_SERVO_PIN);
// Initializes the positions of the servo and ESC
esc.write(STOP); // Stops the car
steering.write(STEER_CENTER); // Centers the front wheels
// wait for the car to be setup on the track
delay(GET_READY); // This delay allows you to get the car set in the track once it has been powered on
run = true;
debug = false;
turn = false;
while(run){
esc.write(CRUISE_SPEED); //this line makes the car to accelerate up to the cruise speed
// The next loop is to keep the car running for the time of the race
while(millis() < (RACE_TIME + GET_READY)) { // performs this loop until the race time is reached.
//obstacle = sonarF.ping_cm();
// if(obstacle <= DISTANCE_FROM_OBSTACLE && obstacle > 0) turn = true;
// while(obstacle <= DISTANCE_FROM_OBSTACLE && obstacle > 0){ //this loop steers the car to the left if an obstable is in front
esc.write(TURN_SPEED);
steering.write(STEER_LEFT_VALUE);
delay(29);
// obstacle = sonarF.ping_cm();
if(turn){
steering.write(STEER_RIGHT_END_TURN);
turn = false;
do{
delay(29);
// Input = sonarS.ping_cm();
// if (Input == 0 && debug) Serial.println(" Error reading distance, no correction");
// } while (Input == 0);
// steering.write(STEER_CENTER - Output);
if(debug){
Serial.print("Distance = ");
// Serial.print(Input);
Serial.print(" correction = ");
Serial.println(Output);
if(debug){
Serial.println(" NO correction performed");
esc.write(STOP);
run = false;
Please read and follow the directions in the "How to use this forum" post.
Be sure to edit your post to add code tags.
    do{
What is this supposed to do? There is a do/while statement in C. There is NO do statement.
PaulS:
    do{
I see its corresponding "while" is remmed out.
meganator1234:
Help others help you by explaining exactly what those problems are, and what error messages (if any) you get.
Side note: I wonder what made the authors of the code think that servos managed through the Servo library need to be on pwm pins?
