robotics
i want to connect RPM Tracking sensor(input) to the board and using this data(input ) operate the two solenoids with in the time 0- 25 milliseconds which ARDUINO BOARD is suitable for my project.
RPM =3000 to 6000 solenoid type = DC Voltage =12 v soleniods speed =0 to 25 milliseconds
Specifically, what sensor?
What two solenoids?
What does that mean? Read the RPM, and then randomly pick a time in that range, activate the solenoid for that amount of time, and then turn it off?
Any of the blue ones.
PaulS: Any of the blue ones.
Since I can't buy you a beer, we have to settle for Karma++
PaulS:
1Q:Specifically, what sensor?
A: Engine speed(rpm) tracking sensor
2Q :What two solenoids?
A: push and pull type (Linear motion ) solenoids
3Q: What does that mean? Read the RPM, and then randomly pick a time in that range, activate the solenoid for that amount of time, and then turn it off?
A: yes you are right
4Q:Any of the blue ones.
A: Iam cannot understand this statement
5Q:can add these two atduino boards?
(Arduino Uno REV3 [Original - Made in Italy] ATmega328P) and
(New 2A H-Bridge 2 way DC Motor Driver Module L298P Shield For Arduino)
@NEELISAMPATH, Do you have links to the datasheets for your sensor and solenoids?
Or have you not decided yet which you will get?
4Q:Any of the blue ones. A: Iam cannot understand this statement
This was a humorous way of saying that any arduino will work for this task.
vinceherman: @NEELISAMPATH,
Do you have links to the datasheets for your sensor and solenoids? i dont have data sheet
yes
OPs two images,
Tom… :slight_smile:
Hi, What we need are;
  • Data/specs for the sensor.
  • Data/specs for the solenoids.
What is the application? What are you trying to accomplish?
Tom... :)
TomGeorge: Hi, What we need are;
Requirements of solenoids
1) Voltage - 12 v 2) Stroke - 80 to 100 mm (pull and push type) 3) Force - 700N (operate the 125 cc bike engine valve) 4) Duty cycle - 30 to 35 mins 5) Response speed** - 0 to 25 milliseconds 6) Type - DC 7) Quantity - 2 8) Structure - Tubular
** Stroke complete in 0 to 25 milliseconds
sensor requirements
"Segolike Car Engine Crankshaft Position Sensor for VW Passat B5 Bora OEM 0261210165" 1)hall type sensor 2)RPM-5000
