robust bee network advice
I'm trying to figure out the most robust way to set up a network of 3 (and perhaps more) xbee 900 pro x3b 9600 radios. This would service an existing water monitoring system.
I currently have a single remote station (site #1) at the water tanks that gathers data from a variety of sensors. The station runs off an arduino mega and aggregates the data for subsequent download to an iPhone app I wrote. If I'm away, the data may persist for up to 2 weeks before download.
With the bee's I'd like to accomplish 2 things:
  1. Add a remote sensor at the pump house so I know exactly when and for how long the well pump is running. This would be site #2.
  2. Download the data automatically from #1 to my house at site #3
Note that the sites are in a wooded hilly area. I did a simple test to see if the radios will actually work and I get a reasonable signal between #1-#2 and
1-#3. I used simple broadcast between all the sites and did see that the
data did contain some errors.
Since from the xbee documentation, broadcast communications are not error checked or acknowledged, I need to set up the radios for more robust communications. This will mean using an actual "destination address" (not broadcast) and setting up retries, etc.
The problem is that the radio #1, at the main remote station, needs to request data from #2 and then send it to #3. This means that radio #1 needs point-to-point to 2 different radios.
I see 2 solutions:
  1. Add code to #1 so that it changes the "destination address", using the "ATDT" xbee command, depending on whether it is requesting data from the pump house (#2) or sending data to the house (#3). I've already got arduino code that allows me to read the signal strength ("ATRS") but this seems like a hack.
  2. Although the documentation flow charts are awful (there is no entry point specified!), it seems like I might be able to play around with the address mask so through careful choice of address (MY parameter) I might be able to avoid changing the "destination address". I can't really tell from the docs if this would work. (I may sit down with XCTU and 2 radios and try to figure it out empirically but I really shouldn't have to do that…)
At this point, it seems like what I need to do should be pretty common (main sensor site gathers data from remote sites then forwards it to another site). Any advice would be appreciated.
jim barstow
I see 2 solutions:
3) Use Andrew Rapp's XBee library, which lets any Series 1 or Series 2 XBee talk SPECIFICALLY to one other XBee, because it uses API mode.
PaulS: 3) Use Andrew Rapp's XBee library, which lets any Series 1 or Series 2 XBee talk SPECIFICALLY to one other XBee, because it uses API mode.
I looked into that but I can't get a straight answer as to whether api mode is actually supported on the xbee pro xsc s3b. The documentation doesn't even list an AP command for going into api mode. When I try to use it in xctu, I get an error. Some radios require a firmware change to support API mode but the available firmware for these radios don't list anything pertaining to api mode. There is a "binary" command mode but it is different than "api mode".
So, what made you choose those particular models? Do you have a link?
PaulS: So, what made you choose those particular models? Do you have a link?
longest range and lowest power. They are being used in hilly country with lots of oaks. Longest line of site is about 40 feet. When I looked at the various choices, these were the clear winner. There were no flags whatsoever that API mode wasn't supported. I've post 2 questions on the digi site to clarify the lack of API mode and have gotten no response. The only way to open an official "support case" with digi is to pay $35.
