Hello I am trying to wire a 3 prong rocker switch to My pro micro I just do not know what pint to connect to on my pro micro in order for the led light to work
We need you to flesh out this a bit more.
Have you gone thru the examples that come with the IDE ?
I'm not sure what ypu mean by ide but here is the rocker switch that I am trying to use but I just don't know where to wore the led pin from my rocker switch to my pro micro
The key part of that data is this:
(http://sphinx.mythic-beasts.com/~markt/switch_led_pinout.png)
Common to power, one side to load, other via the bulb/led to ground - perhaps.
[ hmm new website seems to have broken image posting for me... ]
What in not understanding is what is the gold pin and what pin do I connect to on my aurdino pro micro
If it ‘just’ has a LED, you will need to add a series resistor to the the switch.
Do you have a DMM ?
What do u mean by is it just a led I'm not sure about that all im using it for is to act as like a button in a sim game and I don't know what ddm means
Do you have a DMM ?
A DMM is a digital multimeter.
If so, identify what the resistance readings are between terminals.
Identify the terminals for the anode/cathode of the internal LED.
Just put the URL itself on a separate line.
However the particular URL you posted is mendaciously blocked from hyperlinking. Typical sociopathic website! ![]()
If you click on the "blocked" image you will of course see it.
