Rocket engine throttling help
In this code portion, you have decided with 1 test that if the dumpin is HIGH, to dump the N2O. In the next portion of the code you do 1 test to decide to trigger the ignitor. In both cases the delay is after the result of the "if" has began. I am wondering if you want to "double check" the pin before passing the "if" statement.
val = digitalRead(dumppin);        // Read dump trigger input value and store it in val
  if (val == HIGH) {               // Check if dump trigger has been tripped
    analogWrite(valvePin, 255);    // Open valve and dump N20
    delay(15000);		   // Wait for 15 seconds
    analogWrite(valvePin, 0);      // Close valve
