Hello I have custom LCD with RW1025 controller for I2C interface below Image.
https://1drv.ms/u/s!AgpZkEb40j7ahsU5BPZqy6WtnwdwGw
I can't find out any sample code for Arduino.
I tried to build myself but it is too complex manual for datasheet attached file and below links.
http://www.rockworks.com.tw/homepage/dldatasheet/dldatasheet.php?action=datasheet&fn=RW1025_V0.1_160303&dir=./dldatasheet/datasheet/RW1025_V0.1_160303.pdf
I need help.
here is my code doing. Currently, I2C address scanning is working well.
#include <Wire.h>
#define I2C_ADDRESS 0x3E //0b0111110
void writeCommand(uint8_t command);
void writeData(uint8_t data);
void writeString(uint8_t count, uint8_t *MSG);
void Initialize_CFAH2004AC(void);
void Initialize_CGRAM(void);
//Assert the CS
//CLR_CS;
Wire.beginTransmission(I2C_ADDRESS);
//Send the command via I2C:
Wire.write(0x00);
Wire.write(command);
Wire.endTransmission();
//Deassert the CS
//SET_CS;
delay(1);
//Assert the CS
//CLR_CS;
//Send the data via I2C:
Wire.write(0xC0); //Control Byte - Data (non-continued)
Wire.write(data);
//Deassert the CS
//SET_CS;
delay(1);
void writeString(uint8_t count,uint8_t MSG)
for(uint8_t i = 0; i<count;i++)
writeData(MSG);*
void Initialize_CFAH2004AC()
//LCD Init*
delay(50);*
writeCommand(0x38); // Function set*
delay(1);*
writeCommand(0x0C); // Display ON/OFF*
delay(1);*
writeCommand(0x01); // Clear display*
delay(10);*
writeCommand(0x06); // Entry mode set*
delay(1);*
void setup( void )
//DDRB |= 0xFF;*
//debug console*
Serial.begin(9600);*
Serial.println(F("setup()"));*
Wire.begin(); // join i2c bus (address optional for master)*
//Fire up the I2C LCD*
Serial.println(F("Initialize_CFAH2004AC()"));*
Initialize_CFAH2004AC();*
void loop(void){
- Serial.println("loop");*
- delay(1000);*
- writeCommand(0x38); // Function set*
UNLCM11001规格书.pdf (225 KB)
