Rolling Array
Hi everybody, i've got some issues concerning running average library
I'm reading values from a sensor.
I would like to have only the last 100 values of the sensor.
{value (t-100*delay) , value(t-99*delay),  ....  ,value(t-delay)}
// with value(t) = analogRead(SENSEPIN)
I'm using RunningAverage library to shift the values in the array.
The fact is that when i declare my Running Average array, i can't access to an element in particular, i can just access to the average and add a new value.
#include "RunningAverage.h"
RunningAverage myRA(100); //créé un array de 100 valeurs
int samples = 0;
int SENSEPIN = 7;
void setup(void)
  myRA.clear();
void loop(void)
  int rn = analogRead(SENSEPIN); //reading sensor value
  myRA.addValue(rn);  //adding it to myRA (which places the value to the last position and shift the rest of   the values
  samples++;
  Serial.println("Running Average: ");
  Serial.println(myRA.getAverage(), 2);
  Serial.println("The Last value of the array is : ");
  Serial.println(myRA.getElement(80)); //here i can't get the last element, i've got nan and then a fix value like 566...
  delay(100);
  if (samples == 300)
    samples = 0;
I really need to access the last value in order to apply some kind of a filter on it :
 if ( abs(lastValue - actualValue) >= x )
//remove the value
// wait
// measure again
Not sure the RunningAverage is the best way but that's the most popular way i've found to shift values in an array.
Thanks a lot !
from Rob's class:
Are you sure there is a value in element 80?
// returns the value of an element if exist, 0 otherwise
float RunningAverage::getElement(uint8_t idx)
    if (idx >=_cnt ) return NAN;
    return _ar[idx];
separate to that:
which element is the last?
Ok, indeed, i didn't wait enough time.
The problem is that the last element doesn't change every measure (and it should be because of add.value)
Chuoby:
why do you think that the last value should change?
again, from Rob's class:
void RunningAverage::addValue(float f)
    if (_ar == NULL) return;
    _sum -= _ar[_idx];
    _ar[_idx] = f;
    _sum += _ar[_idx];
    _idx++;
    if (_idx == _size) _idx = 0;  // faster than %
    if (_cnt < _size) _cnt++;
it appears he moves _idx and doesn't cascade the values back in the array
Thank you for your answer ! Yet i didn't understood very well if it's possible to access the last element added to the array.
You will have to add a function to the library to get access to the last element.
That could be a function that returns the index of the last added value, or the value itself.
You could use variable in your sketch that holds the last added value.
Am I missing something?
The newest value in the array is the one you just put there.
AWOL:
The library moves a protected index to the next element of the array to deposit the next value.
There isn't a method to retrieve the last value entered, in the case where you went off the reservation, scope-wise.
